Stickered up race-looking charcoal R32 on the back of a trailer going down Bayswater Road at about 5:15pm tonight. Plates 'GOZILA' I think? I swear I've seen the exact same one going down there on a trailer before.
Yeah, when I met him, we actually spoke of you lol, he was saying one of his mate used to own a MR2 and is on SAU, and I'm like, I know that kid! lols
Haha :) I know all the local import drivers. Mainly because I go out of my way to talk to them when I see them (Yuri for example).
Keep seeing a white R33 shortly before 9am on Mitcham Rd. Haven't seen the plates but I'm fairly sure it's the same one every day (I mean, how many white R33s are there? lol)
haha thats me adam, i start at 9 and go down mitcham rd lol
Spotted R32 GTR in gun metal on wester ring road Greensborough bound after tulla fwy, had 'Edge Motors' or something like that on the back.
Then inbetween Dalton and Plenty saw another gunmetal grey 32 and a yellow R33 with a body kit heading the opposite way.
Oh, and a douche bag in a ford who wouldn't stop hanging out his window >_>
theres a clean silver R32 (gtr i think... hard to see) parked in a carpark in hawthorn behind my worksite... has sau stickers
Hey Ruffels, that's ME!!!! It's my reserved spot, bloody impossible to get a carpark in Hawthorn during the work hours. Next time I get in a bit early and have time, if you see me yell out, I'll have a chat. Oh yeah and it is a GTR VSpecII :devil:
What are you guys building there? Last I heard it was going to be a doctors surgery or something.
Spotted a midnight purple r32 gtr with gold rims and no spoiler with sau stickers on the rear quater windows. At the sparkling carwash on burwood hwy last night. There was a VIC imports mini meet going on when u rocked up I was leaving
Could be Aaron's R32 GTR from Import Monster... But her has a Nismo Boot Lip Spoiler...
Nah I'm pretty sure there was no lip or spoiler at all. The rims could have been bronze too. Somthing dark. Looked pretty shweeet
Hey Ruffels, that's ME!!!! It's my reserved spot, bloody impossible to get a carpark in Hawthorn during the work hours. Next time I get in a bit early and have time, if you see me yell out, I'll have a chat. Oh yeah and it is a GTR VSpecII :D
it's going to be an optomitrist / eye surgery place... funny because we (tradesman) have been told to keep it a secret, and on the plans its marked as a "gym" just incase people try and find out what its going to be.
why the big secret :D
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
