because CTP is TAC I called it that because VIC are the only ones to not call it CTP. And in the quote, yes I did say CTP or comprehensive but it should have read TP (Third Party) my mistake for the typo but didn't think it was too hard to figure out. Next time I'll be sure to check my spelling and grammar before I post on a forum :D
Anyways, should probably keep this thread on topic rather than bitch about something that I already admitted ages ago I was wrong about and then gave the proper info afterwards.
spotted a white r34 gtt on the lancefield romsey road than you turned left and so did i and when you turned right i tried to get beside you to say hi but you were already turning. nice car also, looks very clean and you live not that far from me also.
Just saw a dark (probably black) r33 gtr trying to drag me all the way down monash and then on cranbourne narre road... i didnt respond so he got the finger out when he turned into his street... like who tries to drag a N/A in a GTR? fail
lol pretty sad to stick the finger out just because someone doesn't want to go.
Shame on them.
Yep that was me..
Apparently my Ps wernt showing even though they were up
Bald tires on rear (fair enough, already replaced and cleared that)
And I took off a little fast at the lights because my cousin said that there was a hot chick ahead.. again my fault but wasnt anything bad, not even like N/As go fast
he just did me for the tires then and there and told me the other 2 will be in the mail even though he told me to pick one.. so i was like wahhh? then he just like walked off so not sure on whats going to happen hopefully i dont get anything in the mail and it was just a scare as i get off my Ps in 1 month
just for you :bunny:
:) haha cheers man will look better once its not tractor height! what brand are ur l.e.d tails in your dp i want some bad! dont tell me nismo either or ill cry.. i like them just not 1400 worth haha. dont see many nice skylines leaving pettit town anymore... pussys! lol
yeh they are nismo lol i was lucky they came with the car :) im not to fussed bout pettit anymore ive gone past him plenty of times now and he hasnt done anything from my last run in id say im on his good side. besides hes posted in lilydale now
Might have been me, like before 8am? But I get on the ring road there.
It was at about 7.40-45-50, could have been entering or exiting, was just in that part that runs parallel to the fwy. Too bad it was shit traffic and I couldn't catch up to say hello!
Were you in the 34 or the bike in your sig? Yeh I go that way everyday, traffic is always a major pain in the butt on the ring road!! Il keep an eye out next time!!!! :banana:
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
