because CTP is TAC I called it that because VIC are the only ones to not call it CTP. And in the quote, yes I did say CTP or comprehensive but it should have read TP (Third Party) my mistake for the typo but didn't think it was too hard to figure out. Next time I'll be sure to check my spelling and grammar before I post on a forum :D
Anyways, should probably keep this thread on topic rather than bitch about something that I already admitted ages ago I was wrong about and then gave the proper info afterwards.
spotted a white r34 gtt on the lancefield romsey road than you turned left and so did i and when you turned right i tried to get beside you to say hi but you were already turning. nice car also, looks very clean and you live not that far from me also.
Just saw a dark (probably black) r33 gtr trying to drag me all the way down monash and then on cranbourne narre road... i didnt respond so he got the finger out when he turned into his street... like who tries to drag a N/A in a GTR? fail
lol pretty sad to stick the finger out just because someone doesn't want to go.
Shame on them.
Yep that was me..
Apparently my Ps wernt showing even though they were up
Bald tires on rear (fair enough, already replaced and cleared that)
And I took off a little fast at the lights because my cousin said that there was a hot chick ahead.. again my fault but wasnt anything bad, not even like N/As go fast
he just did me for the tires then and there and told me the other 2 will be in the mail even though he told me to pick one.. so i was like wahhh? then he just like walked off so not sure on whats going to happen hopefully i dont get anything in the mail and it was just a scare as i get off my Ps in 1 month
just for you :bunny:
:) haha cheers man will look better once its not tractor height! what brand are ur l.e.d tails in your dp i want some bad! dont tell me nismo either or ill cry.. i like them just not 1400 worth haha. dont see many nice skylines leaving pettit town anymore... pussys! lol
yeh they are nismo lol i was lucky they came with the car :) im not to fussed bout pettit anymore ive gone past him plenty of times now and he hasnt done anything from my last run in id say im on his good side. besides hes posted in lilydale now
Might have been me, like before 8am? But I get on the ring road there.
It was at about 7.40-45-50, could have been entering or exiting, was just in that part that runs parallel to the fwy. Too bad it was shit traffic and I couldn't catch up to say hello!
Were you in the 34 or the bike in your sig? Yeh I go that way everyday, traffic is always a major pain in the butt on the ring road!! Il keep an eye out next time!!!! :banana:
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
