dark blue R35 at tunstall square - told him nice car :P
I'm sure I saw you turning into Doncaster Rd from Manningham Rd about 6.20pm last night(Tuesday), unless someone is rocking ultra awesome wheels that I'm very familiar with...
lol must of been me then man!
dont remember it though lol :P
