Saw that light blue golf with the bbs that was at the show and shine on the hwy turning onto springvale road yesterday at about 3ish I was in a mates silver stag
Didn't sound as loud as I tought it did at the show and shine
Haha yeah I heard the dose and saw you guys :P
was only cruising along, 80km/h in 6th gear keeps it nice and quiet. :)
Needs a wash badly though :(
aha was me :D
i think ive seen your car around before! :D
looks nice man
hahah probably.. i get around. :)
it was dirty as. hadn't been cleaned in 3 weeks and still hasn't hahaha
will probably see you a lot more if you live around that area. :thumbsup:
Nice Bayside Blue R34 Gtr Vspec2 through Doncaster around 5pm last night. Sounded rather loud.
Being a R32 tragic for their aus motorsport history I do see the appeal in a modded R34 when I see one in the flesh. I think if I had a R34 though, i would have to mod it to within a inch of it's high reving gt life... whereas I cant wait for the excuse to put a 3.4 small turbo road grunter in the R32.
LOL oops my bad :/
I live literally 2 streets away lol
looked clean! much cleaner than mine! havent washed it in like 2 months :(
might have to have a cruise with you if your around there alot :P
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
