After changing (years ago) from a slightly modded GTST, standard ECU, to an un-tuned Power FC....
I obvisouly noticed a better midrange in power and better drivabilty overall.....even before tuned...and even better after!
My question is this,
If i have a, lets say, a 2000yr, 1.8 Corolla, is it worth adding a piggy back to punch in some extra timing and getting that better feal?
Would it work?
Are NA standard cars already at their optimum or are they running super safe where you could squeeze some extra omph outta them?
What are your thoughts?
NA cars won't lean out as easily as a turbo car, so they don't have to be as careful with the tune I guess. There are always things you can do with an NA though, like advancing the timing for instance.
All OEM cars are tuned conservatively. You can always find a little extra by tuning the ECU, especially if you're willing to always run it on a higher octane fuel. Then there's removing inherent restrictions like the intake and exhaust if you're willing to put up with a bit more noise.
As for whether its "worth" it, its up to you. You'll still need to spend money on it, and you won't see the gains you would on an FI car. If you have to have more punch and you can afford it, then do it. But I get the feeling you've got better things to spend your money on than getting a handful of fwkW on a $600 outlay with an A'PEXi S-AFC.
I had a very clean EF falcon.It was one of my most enjoyable cars.
Full exhuast
Headers
XR ECU and fuel reg
Cam
Valve springs
Lowered springs
KYB shocks
Nice wheels
I wish i never sold it. :P
Not the fastest thing in the world,but it sounded horn and was a great drive.I only mod inline 6s though.4s dont do it for me.
Its definitely worth it You will see roughly 14+kw gain from intake + exhaust
Sky is the limit. plenty of go fast bits for them! more than enough market and experience out there
twincam.net will be the best place to ask around :P
I love the power delivery and throttle response from my z...
but nothing compares to the rush when the skyline's on boost :P .
Most n/a 4 banger posers add a cannon and leave it at that.
I would do;
2.5" exhaust
good size extractors (not too large)
hi flow panel filter
adjustable cams
decent Air/Fuel management
in the end its going to be a 1.8 corolla, put a better flowing exhaust on it, filter, spend some money on suspension parts and put some nice work rims on it....
no point in modding the engine with a computer etc to get 5extra fwkw
i had an r33 gts-4 non-turbo with the rb25de engine
it had pod, zorst and unichip ecu which made a ridiculously pathetic 78awkw!
a full 2kw gain for 900bux
:laughing-smiley-014:
Thanks for all your replies.
I guess i was hoping for some sort of easy piggy back ECU that could easily be tuned from the passenger seat....leaving AFR's and punching in an extra 5' of timing or something for $500??
I'm more interested in an increase in low-midrange torque feal, upgrades.
Not interested in top output power ( i guess i shoulda stated that earlier)
Thinking i'll just leave it as is.
Cheers big ears.
Birnie :P
Would it work?
It's like giving a fat boy a pair of Nikes and asking him to run quickly... won't happen. So why bother?
worth tuning an NA car? it's not even worth driving one.... :D
ok ok.. some of us haven't earned our boost wings yet. I'm glad my first car was a charade i probably would have killed myself in anything quicker :D
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
