  • Replies 1.9k
shoudl add in
he likes to run people into the wall
pete is very tall
but he has no balls at all
and if you drive beside him, he will put you in the wall
better?
pete is very tall
better?
Gold the creative juices are going. Not fats not literally. Oh deer this is going down hill.
Wizard just stumbled across this funny?? Check this out this You Tube link of my car only I know it is Jack B ( JagR33) R33 GTR. Someone is confused. Don't tell me GTR wants to be a zed now or just trying to make me look good??
Edited by Boosted Zed
I think the GT2 will smash the AMG to be honest. Pretty sure the AMG 0-100km is 4.2 and the GT2 is 3.6 seconds!!!
Can't wait to see what times they do around the circuits. I know it is off topic but I will keep you all posted.
It would be nice if you could sweet talk to Nissan to bring out the R35 as well for some comparison.
Please keep us posted and a lot of pictures would be nice :)
WTF??
How did that video get there??
He must have pinched it from one of the PI track day wrap up threads in the VIC section.
Oh well, now all the clubman class competitors can see what they're up against... :)
WTF??
looks like an awsome track to drive on!!
cant wait to get the chance oneday
Hey JP
For sure at oran with the black pair on thursday. Could be in the morning now.
We will have the R35 for PCOTY and do a full comparo with the fastest and best cars available in aust throughout the year. Should be interesting when the R35 comes up against the GT2.
Have just got home and used a tank of juice in a few hours in the BLACK clk :)
This thing has serious mumbo :D
This thing has serious mumbo :)
:D <singing> Have I told you..... lately.............. that I hate you.... </singing> :D
Just heading out the door to meet up with the GT2.
We are heading through Picton and the south coast today. Will end up at Wakefield just before 3pm to have a couple of hours on the circuit with both!!!
Eastern creek is out today but will be at Oran tomorrow with both.
May go through alot more than one tank of juice today ;)
Cool hope weather is good as will be tops to see these black beasts in action.
Also looks like whoever posted that vid on You Tube has changed the name to Nissan R33 GTR.
Yes Russ it is an awesome track, one of the best in the world.
WTF??
Oh well, now all the clubman class competitors can see what they're up against... ;)
You should have stayed in 4th over the top of Lukies - I hear that works better :D
Actually have the IPRA cars been to the Island or do they just live in NSW?
we will be there,
i know matt from queensland is driving down with an r32 gtr , which is pretty pretty hardcore, ppg & dry sump setup.
JP will be there
Bozman will be there with two very very nice road cars!
Beer Baron in his S15
John Bright in his r32 gtr too , very quick
i hope there are some more
Edited by giant
No GTR IPRA cars in Vic.
Cheers
Gary
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
