Hi all,
There's a wealth of info in the rb30 thread - but it would be nice to have a thread about what pistons everyone's used - CR, head gasket used for CR, forged or not, brand, pin heights etc etc.
I saw one guy in the rb30 hybrid upgrade dyno results thread is using 10:1 pistons on a turbo rb30.
Please post away your piston specs - I'm in the process of doing up a rb30 so would appreciate any input!
Cheers
https://www.sau.com.au/forums/topic/212676-pistons-for-your-rb30/
I have 8.3:1 CR, Stock pistons, OEM RB26 Head gasket
How is it off boost?
Aries Pistons, probably can go better but never had a problem and made massive power..
CP's - look on Ebay US, they're cheap as!
Hi there,
Just was checking out Ebay US but couldn't find CP's for Rb30's - do you have a link?
Cheers
I only found the MAHLE RB30 pistons
MAHLE RB30DET
Also these cheap Rods...
Rods
Seems very cheap...just over $1k delivered for forged bottom end parts (how strong thats another question...assuming its at least better then a standard rebuild).
Would those rods suit those pistons ?
Edited by KISIN
good i think? bit hard to say cause i dont have anything to compare too apart from the 25 which this motor eats for breakfast off boost!
how would you expect it to feel?
Hard to say on the net, sluggish i guess is the closest word
....havent been on the forum for long so sorry if this has been covered a billion times.
But when doing the 25/6 head swap on the 30 bottom end doesnt it lower the compression a fair bit due to chamber size (i think i read that sumwhere).
Anyways, how much does it lower it, say if you have 9.5:1 CR with a rb30et, wat would comp be if you just did the str8 up 25 head swap and didnt touch the bottom end?
Thanks
Jon
Edited by VKYOOT
we just got a new set of mahle 40 thou oversize forged pistons from hi octane. They look very schmick!
Will be the first set of pistons used in one of the many rb30 builds weve done that hasnt come from CP.
Judging by the specs on the piston box i imagine it will net a comp ratio of about 8.2:1, same as the flat tops CP provide for the conversion.
Edited by r33_racer
Thanks
Jon
About 8.8 at a guess
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
