  • Replies 456
Posted Images
  • 3 weeks later...
hahaha, was searching for real world pics of the new(ish) silver/black font plates and found this in google images
:D
yours for $5000!
http://www.gumtree.com.au/s-ad/melbourne-region/other-parts-accessories/nekmnt-number-plates-vic/1010328399
i know Vu's old car had the gold font on black background, but has anyone seen/got the silver font on black background? is it metallic or flat silver? interested to see some examples...
  • 11 years later...
On 01/04/2008 at 12:17 AM, Phatboy said:
Hi, not sure whether this has been posted elsewhere, but couldn't find it on the search button.
What nice plates have people seen around Victoria?
Specifically in the last week or so for Nissans:
[GTRHKS] I just rode in it on weekend - Silver R33 GTR quite modified
[N1SMO] - Blue modified S15 owned by same guy
[GTRJIE] - white very nice R34 GTR driving around Melb owned by guy named Jie
Other plates I have seen over the years but can't remember car type:
[LOSER]
[FATBOY]
[P1GB8T] - "pigbait" on Wrx I think
[iMPOOR] - very flash car, can't remember what exactly
[i000HP]
[bOOKME]
[NORICE]
[RICER]
[sTOLEN]
[WASHIS] - ex-wife?
No-one has taken [GAYLOR] though, I wish someone would :glare:
I am trying to get some ideas of something to put on my custom plates for a R34 GTR. Any recommendations?
I know these are currently available, but they are a bit gay...
[FUNGTR]
[GTRFUN]
[R34PWR]
[sTOVES]
[PHTBOY]
[RDARME]
[GODLY]
[HKSCAR]
[bNR34V]
How about [HASTE] or [RAZER] (as in to raze everything before me lol)
MUD....suit  4 wheeler..brick layers
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
