  • Replies 245
Posted Images
consider youselves lucky
im an electrician. does not matter how much i earn as it all goes to my girlfriend anyways! :P
I know someone else that would say that too. :P
I work for my Grandparents as an admin assisitant, best job ever.
Lukes a fitter/machinest slash CNC programer aka Mechanical Engineer.
https://www.sau.com.au/forums/topic/213419-your-job/page/5/#findComment-3775362
Grog ofcourse :)
my garage is full of past used by date beer if that helps
I wish i had a spare million for a cnc machine. Just think of the rediculous things i could make
https://www.sau.com.au/forums/topic/213419-your-job/page/5/#findComment-3775644
I make the holes in the middle of dohnuts. good pay but very high pressure job to get it just right. I also do muffin stump removal like newman and previously worked as a mercenary during gulf war 1, gulf war 2 and gulf war 3 "payback". follow your dreams!
https://www.sau.com.au/forums/topic/213419-your-job/page/5/#findComment-3775658
I'm a software engineer / web developer (what a shock!!) for realestate.com.au.
Christian
# Give agents more then 26 upload options for photo's.
# For the love of god, write a tech article for idiot agents on how to resize images. Alot still manage to upload pixilated photo’s.
https://www.sau.com.au/forums/topic/213419-your-job/page/5/#findComment-3775810
Tell me about it! I used to get so annoyed with that website! Although not as bad as justlisted.com.au
https://www.sau.com.au/forums/topic/213419-your-job/page/5/#findComment-3775829
tell them i'm sick of paying for advertising on there. make it free for me prankeh! I need to advertise my place this week. :)
cutting the holes out of doughnuts for a crust has not exactly left me rolling in dough... ahhh nuts!, pun overload!
https://www.sau.com.au/forums/topic/213419-your-job/page/5/#findComment-3775914
LOL...
https://www.sau.com.au/forums/topic/213419-your-job/page/5/#findComment-3775998
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
