  • Replies 344
Posted Images
You wants it??? you could at least use it as a theatening tool on your flatmates :D
haha yeah on Alberts car.... think it fell off or he ripped it off... didnt see
If anyone wants it let me know............. Otherwise Il bring it to the next Texi :whistling:
I don't really think anyone wants it back now that you've had some "alone" time with it.... :blush::ermm::D
Except maybe MattyD, he's a fiend! :D
sure, why not :blush:
Great pics everyone!!! There's a lot of camera talent and chub worthy cameras floating around! A big thanks to all who took shots of the GTrevolution :whistling:
Can we have some times posted yet? Pllllllllllllleeeeeeeeeeeeasaaaaaaaaassssse? :ermm:
For some reason you want everyone to know you got spanked by a GT-T running .3 bar? ^_^
sooo. wanna make out or something? :whistling:
lol.. it made it to the engine crane where it has remained... I may bring it to the pizza cruise though just for shitsngiggles..........
They received a noise complaint from a nearby farmer I believe... That was about it, he just wanted to take some readings and talk to the owners of the centre about what was going on... they have some weird sound credit thing going on that we didn't know about...
    • If you get 12v at one of the relay pins with IGN on, and 12v at another for about 3 sec when you turn the key from ACC to start, then yes you can just earth the relay trigger pin. Just have a look at the top of the relay, it should tell you which pin needs earth when the 12v signal is sent (or if it's not clear, just post the pic and we can work it out). If you always have 12v at 2 pins with IGN on, they it is earth triggered by the ECU which makes it harder to fix (you really need to check the ECU pin is earthing when it should, and if so it is a wiring issue from there to the relay.
    • Tomei make a 1.5mm restrictor, I'd just use that.
    • Got the gearbox in and the front drive shafts.
    • Hi There I went through a rabbit hole of reading about Xenon headlights and the ADR regulations for having them installed. As people have been defected by running factory xenon I was researching in ways to make them compliant. Everyone always say needs to be self leveling and have washer installed, which I don't necessarily agree with. For this argument I'm using R34 as reference as I'm more aware on the construction of the headlight compared to the R33 Xenon, which may still be the exact same case.   For the self leveling clause taken from ADR 13 - Installation of Lighting and Light Signalling Devices on other than L-Group Vehicles As you can see the bold text "these manually adjustable devices from driver seats" are fine to use. As Series 1 Xenon model headlights do have a 4 level adjuster on the right near the ignition (however not series 2) then these model are consider compliant in that argument.   For the Self Cleaning aspect of this argument clause taken from ADR 13 - Installation of Lighting and Light Signalling Devices on other than L-Group Vehicles Now i can understand the argument that Xenon will need a washer as they are over 2000 lumens, but I clicked on the 12 at the end of that sentence and it takes me to the end notes which states R34 for headlight lenses are plastic, not sure if PL is mark as I don't currently have my skyline to confirm that marking is there. But could you not technically get a lenses with the PL marking on it and then get away with the argument that you need a washer. I went through a quick read of the adr and might have missed something else that may cause them to be non-complaint.    But wouldn't these technically be complaint headlights   Would love to hear other people input on this and shed some light   Edit In regard to the the washer portion I might be mistaken ADR 45 (which I believe is Regulation NO.45) states 12 cd (candela) I dont understand that portion in regarding to calculating the candela if anyone can shed some light. Otherwise I guess throw in a washer for the headlight and you definitely comply.
    • Took it to all Japan day, flogged the hell out of it and took it all, am a very very happy man  don’t know how that ended up in Greg’s thread before
