  • Replies 895
Sorry if this has been covered to lazy to read the whole 10 pages but can this ecu be used with auto equipped cars or strictly manual only and is there a price list somewhere for all the different models
all but the auto r34...which is being worked on and will be released soon.
the plug in is a board...needs to be installed into a STD Nissan case.
so by that we need 2 have an original ecu 2 fit it into or will they b fitted in 1 when we buy it as im gona get when when i have the money but my car has a power fc and dont wana pull it apart as i wanna sell it after i fit the vipec
interested to see differences between PFC and Vipec on a street GTR. Anyone have before and after data?
i should be able to post up details next week sometime afteri get the vi-pec installed in my 32r
just waiting for a date nd time for the install
Got a little bit of news on the V66...yes its based on the V44 but is a special one off item specifically designed for the Skyline and features direct fire ignition. I was worried it might be a wasted spark set-up but no its direct fire. Still a couple of weeks before i get some in stock...illl let you know when its here.
Paul,
According to the documentation ( http://www.vi-pec.com/techdata/Vi-PEC_Niss...-GTR_PlugIn.pdf ) it does run as a wasted spark setup.
The base model Nissan GTS-GTR VX Plug-In ECU has four
ignition drivers. This means that on a six cylinder engine the
ignition coils are run in a wasted spark configuration. For future
upgrade reasons Ignition 3 and Ignition 4 channels are joined
together.
(page 22 of the PDF)
Also neither the documentation nor the website says if you can use the launch control with the V66.
Does the Anti lag come included as standard?
Can it do boost control (if it does is it supplied with the solenoid?)
Is it supplied with the intake air temp sensor? (basically what is the unit supplied with?)
Finally, do you have a price yet?
The only feature I see of this ECU, that is beating the Adaptronic e420c, is the auto gearbox control.
And hey, the e420c costs around $1290RRP, with the plugin loom, runs map, boost control, launch control, traction control, dual maps, will do what you want it to when it sees knock, so many features in the Adaptronic.
Closed loop idle, fuelling changes dependent on temp.
All software and upgrades free, and when you get on there forums, or ring the business, you either speak to the Owner, or the 3 guys working for him. All of whom are into there cars, and extremely good at there jobs of fitting the ECU.
So the question for me, deciding between these two ECUs if I was going to, would be "Is $700 more worth it for the auto gearbox control" for me, no it isn't, I run a manual, for the auto guys, it might just be, but you just leave your stock ECU piggy backed in to run the auto and save $700...
I hadn't managed to find the final price, as I got to page 4, and got sick of the one sided bias coming from Dirt Garage who kept knocking everyone down if they passed a comment he didn't agree with... But hey, that's what sales is all about, pushing your point of view...
Its a shame, but I have been contacted by Autronic's solicitors about a post in this thread. I have had my solicitors look over the request and have been advised that it is a reasonable request and not worth disputing. Its for that reason that the post has been removed.
It upsets me that as we are all enthusiasts in the same industry that this had to be requested via a legal third party.
Carry on.
Paul,
Yeah the distributor assured me it was wasted spark...i doubted it...runs good on all cars we have tested it on though. It can be also programmed to run clever features like map/temp so it will only access parts of the map as car heats up...for example on start up restrict you to a 5000rpm rev limit and as car warms up open more and more of the map.
Carry on.
Wow... I guess thats proof for everyone that PranK isn't paranoid, its just how it is.
v88 would provide ignition driver for each cylinder
in practice its not going to be a big issue , you may have slightly more wear in spark plugs as they fire more often . its possible on some mega hp application you may not have enough dwell (recharge) time to get enough electricity to the coil. I doubt this as many mega hp aftermarket ignition systems are wasted spark.
also a tuner once tried to explain to me that the load on the coil that is firing with nothing to ignite is much smaller , so that would explain the lack of dwell time not being an issue . but I could not really understand why load would be less.
Edited by autoworx
Paul,
Any news on the other questions?
lso neither the documentation nor the website says if you can use the launch control with the V66. - need to confirm
Does the Anti lag come included as standard? - need to confirm
Can it do boost control (if it does is it supplied with the solenoid?) - yes , can use stock solenoid . none supplied
Is it supplied with the intake air temp sensor? (basically what is the unit supplied with?) - yes , our ones so far have had air temp supplied
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
