  • Replies 547
Posted Images
Dave did a 1.08.2 and the day it was done he was on full slicks (worn out i think from memory) when the Vic guys were up here on their annual trip.
His CDI f**ked up the night before and meant a late night trip to SAS to get a new one - that was fun
EDIT: Oh and he had problems with the brakes
In... NOT
Oh hang on i have no car....
Ok well i am happy to throw my hand up for helping out again and happy to give out some shotgun advice for newbies...
Before the oldies take a dig, YES i drove a taxi / Cefiro, but it was a fast taxi! :wub:
Edited by A31Deviat
In... NOT
You handing out driving advice? lol
Thats as bad as me handing out driving advice
In... NOT
Before the oldies take a dig, YES i drove a taxi / Cefiro, but it was a fast taxi! :)
cool, putting my hand up for instruction
Actually the way i drive i think i would benefit from 3 instructors at once, one in each passenger seat :-)
IN!!! making the trek from the desert for this one! Payment will be coming shortly Adam. (have to wait for the pigeon carrier to make its long flight)
last time on a dry track i did 1:16's, but i then did 18's next track day in the wet, so estimate around 1:14's if its dry...
I'll help Bobby!!
But with my help you'll go sideways!! :)
I'll come to be an instructor, that is if people are willing to listen to a young fella :)
But seriously, car is off the road since texi, so put me down as an instructor if you like :)
P.s. Might bring the Mighty Starlet
Edited by TURISMO
I'm in!! Payment will be made tomorrow 17/05/08 and i'll email/confirm tomorrow after paying!
In the words of Chubbs "Oh Boy, Oh Boy, Oh Boy!" this is gunna be awesome!!!!!!!!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
