Hey Guys,
Thought I'd throw a couple more into the mix:
1) Kincrome Aluminium Racing Jack - Low Profile for $384.00 (80mm height)
http://www.transquip.com.au/product.aspx?I...&PARENT=605
2) 3 Tonne Aluminium Racing Jack - 93mm height @ $535.00
http://www.apachetools.com.au/index.php?productID=128
Jacks above available locally in OZ.
Cheers,
Ben
  • Replies 158
Posted Images
your local snap-on man will have one. they are nothing like the ones pictured. they are very low and have a very low snout which is at minimum height.
they are the way to go for sure. and they are not a new model, i've been using one for nearly 10 years. at least 7 years +.
  • 3 weeks later...
My home workshop jack is a western tools number . It isnt low by any standard. about 150 mil high but it does lift to a full 80cm height. It rox the schizz for getting the line up off the ground with more than enough room to skate around under the car without feeling clausto. Rated to 1800 kilo too.
Another point to remember if you do purchase one of these higher lift style jacks is that you will also need bigger stronger jack stands to take advantage of them. Like most on here i wont get under a car supported by a jack only so its pointless having a mega lift jack and short jack stands.
true enough
i have 3 tonne jack stands, but they are so big my current jacks dont raise the car high enough to use them lol
im getting one with the krudd money :/
true enough
im getting one with the krudd money :)
I've got the same problem... massive jack stands and a dodgy low lift jack :)
  • 4 weeks later...
  • 2 months later...
Shop is in Smithfield. It is good, however the pin that holds the top handle in place fell to pieces and I haven't had time to replace it.
The foot pump seems to be good, however I really need to go over it and make sure everything is tight.
I'm going to use this jack at the track (even though it weighs 50kg) because the reach and height allows me to easily change tyres without having to drive onto blocks to get jack access.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
