According to the Australia Post Cost calculator: http://www1.auspost.com.au
If I can keep it under 3kg, it will be $38.05 AUS.
As Ive already included Australian postage in the cost of around $8, total would be $250 delivered.
Edited by JiN_MaN
  • Replies 64
I would like one. PM sent.
  • 2 years later...
  • 1 month later...
Sorry to the people I have talked to and then haven't really gotten back too.
After my uni is all over for this year, 25th Novermber, I will happily organise something for those interested.
Express your interest here and late this month we will see if we can make it happen.
I am keen
i'd be keen depending on price and when it is, I think i've already used the christmas present excuse too much in the last few weeks. lol
Hi guys, :)
I was approached by a friend to buy a Stagea Rear Strut Brace. If anybody else wants 1 please let me know. As it was his idea I gave him the choice as to which 1 to buy, He has gone with 'Greddy'.
Pictures attached,
This is not a stagea strut brace I just wanted to show what they look like.
Price is $250 delivered, These are Brand New. Delivery would be around 5 working days.
Please fell free to ask any questions.
Did anyone ever find out where to source one of these? I would sure like to buy one for my S2
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
