Can you tell me how long my piece of string should be?
motor condition, type of use/abuse all move the goal posts. Why would you want to anyway, a stock R33 has no real power in the top end anyway.
Cos, you could R+D it and then tell everyone how long it lasted............
personally if it were my 25 I would not be revving it past 6500, but it's your engine so up to you. sure it will survive 7000 a few times, hell it could survive 8,000 a few times... but for how long?
lol, this is a thread full of comedians.
Find out where the power peaks and drops off, and set the rev limit there.
If your peak power is beyond 7,000rpm, then you have a massive turbo that requires a built engine anyway.
Your shift point shouldn't be at peak power, it should be where you have got an optimal area under the curve. I aim for ~500rpm after peak power...
the idea of rev limiters and tachometer shift lights go hand in hand, when you change gears you want the engine rpm to fall back right into the middle of the power/torque area when the motor is just at its peak power levels...(where the hp and trq curves meet/intersect or are closest to each other...within reason of course)
for example the dyno sheet below for my gts4
the sweet spot is 5150rpm, theoretically i would want the engine rpms when changing up to drop back to anywhere between
4200 and 5300 rpm.
for example if a rb engine bolted to a manual box drops 1100 rpm between 2nd gear to 3rd gear the ideal shift time would be 5000 to 5500 rpm
to get the maximum amount of power when accelerating. this is a rb3026det freshly rebuilt for drift, mildly tuned @8psi so there's not really any call to go over 7000 rpm, and even then you only want to go past 6000 once in top gear.
Edited by nizmonut
question
can the stock engine rev past 7,000 rpm safely??
-stock internals, stock airflow etc
- and assuming your not limited
More to the point - stock airflow (which one assumes is turbo/IC and so on)
Absolutely useless and pointless
Either way, luck of the draw over the limit, might last a while, might last a bit longer, might not
Simple really.
One of my first Power FC tunes on the highflow turbo i had,the rev limit was set at 7500rpm.
Was like this for about 8 months and saw 7500rpm a number of times,though was not held there for any more than about 3 secs.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
