Thanks guys. :closedeyes: It's just an Evo 6 GSR (not a TME), so it has all the luxuries.
What kind of times did she do ?
It posted a 1:04.5 in it's first outing at Wakefield Park in June (at Evo Nationals) and it ran a 1:13.5 at Mallala last month at the Autosport MGEC Time Attack.
Who built it out of curiosity?
built buy browns engineering in QLD, bored 40 thou new endurotec pistons, moly rings, king race bearings, prepd rods, crank collar fitted, rebuilt head ported new seals, lewis drain back kit, head welded n tap'd for vct, new 25 water n oil pumps, not sure if its worth putting arp rod/head bolts and a metal headgasket in or not, will need another manifold for my 3076r
I ended up going with ARP rod and head bolts. My intention was "whilst its all apart you may aswell". Shame it ends up costing a packet though!
IMO RB25/30 + GT3076R is the best combo for a responsive ball tearer combo. The midrange is obnocious!!!
  • 4 weeks later...
yer mines all assembled.. but not sure since its dry to turn her upsidedown and stick some arp rod bolts in her just for piece of mind, head bolt nissans are usually ok, and wont be running a40psi, hopefully have front end done (this is a s14a btw) and engine test fitting over the chrissy break aiming to be on track mid next year.
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
