UOA completed for German Castrol 0w30
Before everyone jumps on it and says its too thin, the car never saw above 85degrees on water/oil, except one really hot day where I think it might have hit 90degrees.
How do you manage to keep oil temp below 85 - you must have an oil cooler. My normal oil temp is 80, and if I start doing some mountain driving, revving it out, it easily climbs past 100deg.
Yes, a Greddy radiator generally keeping my water at 70 degrees. And an oil cooler with no obstruction from the radiator, mounted in the LHS side of the front bar.
Oil is 70 degrees on most days under normal driving.
I see you finally found a test Gareth, how much did it cost?
I ended up paying $32.50 in the end, the choices were http://www.oilcheck.com.au/index.html
or http://www.e-monitor.com.au/
The report looks cool on the first one, but there are "levels" of service you pay for, starting at ~$38.
The first one didn't answer email inquiries, but call them, there customer service is excellent once you do get in contact :)
I will probably post the analysis of BITOG and see what they think. Looks good to me :)
The analysis took 2 days approx, and the report got emailed through. It was delayed because I bought a magnetic sump plug this time so delayed the oil change.
Cheers mate!
Well, now knowing that my gearbox had ATF in it I don't even wanna know what kind of oil was used in the engine. I'll drop the oil after 3,500kms and then keep a look on it. There is definitely no sludge build up that I can see, which is a good sign.
About Racepace using 10W-60 - I would compare that with race teams using 75W-140 in diffs instead of 75W-90 - racing and street driving are two different things. I'm sure 60 will do a great job for engines used for racing, but that doesn't mean you should use it in your daily driver.
On the money you are :)
We use a synthetic 10w60 in our S15 race car along with 85w140 diff oil, it's the way to go for those high temperature environments. I also sell 25w70 to alcohol powered sprint cars lol - the people running them swear by it and it's dirt cheap. Same oil is used in 4000hp+ top fuel dragsters.
How do you know it was ATF? The colour? Because some Redline oils are red in colour. That said, ATF can be used in a manual transmission when 75w90 is too thick, e.g. after reconditioning or if the synchros are giving you grief as a bandaid fix.
racepace use 10w60 as it can be used for daily and track afaik.
the reccomended viscosity for an RB30 is 15w50 (according to motul book at work) and the bottom end design has not changed that much for later RB's
due to the lower cold weight it's better for cold driving, and repeated on/off stuff, but has the thickness to be smashed when required.
RB engines are old technology, and are not setup for 0w30's and such like the engines of today
also, I have a nismo diff and even for a daily it is much better with a 75w140 than a 75w90
for a purely street driven RB i'd stick with motul turbolight 10w40, but if it is stressed regularly (like many many are, the edge 10w60 is a better bet)
as I said before, if my car wasn't dailied at all i'd just go 300V 20w60 :)
Oh cool, let us know how it goes. I've nearly sold out of it :(
Only 1 more box left and the rest I'll be keeping for myself and my track cars. Still a fair bit of M5000 left though.
I would grab that last box mate but that would just be greedy as I have 10 bottles left. lol.
Hahaha I'm banning you from buying it mate, just like you can get a gambler banned from gaming venues.
I usually use Castrol Edge 0w-40w I have not had an issue with this oil however for a change I thought I would try Royal Purple seeing its meant to be the ducks nuts so I bought royal purple 5w-30w and now my engine feels sluggish I think I will be draining the oil out this coming week and going back to castrol edge.
w30 is thought to be too light for rb's 1-2 decades old with many km in the aussie climate. Most people use w40, try RP/sougi/motul 5w40 or 10w40 if you want a change.
Changing oil company and grade means any differences you notice could be an effect of either change.
The only issue with an oil like this is because of the large range it has a lot of friction modifiers to achieve this, this means that it breaks down faster and doesn't last as long so you need to make sure you change it at the proper intervals.
syn-x is still going well
100,000km service kit is on its way too :) ($260AUD from the USA)
might refresh the syn-x when i do the timing belt
Pipster, how does Syn-X compare with M5000, S6000, Motul or the other oils you've used in the past?
Hi Birds - just a query about this S6000 oil people are talking about. Is it impossible to buy in the shops?
How much is it for a 5L?
I'm 1000kms away from my next service, got the filter already, Bosch filter, and now I'm chasing some oils - maybe AMSOIL AMO 10W-40, or maybe I try this S6000 if I can buy some somewhere, or of you.
Cheers.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
