Just a thought.
A sticky thread in this forum section with a high level summary on fluid info for each skyline model would be helpful. (With recommended types and capacity for each car - engine oil, gearbox oil, diff oil, fuel filter part #, oil filter part # - etc).
If there already is a compiled thread like this - please point me in the right direction.
Edited by iwanta34gtr
Thanks for the reply mate.
Still a bit torn between 10w40 and 10w50?
And will a 5L bottle be enough for my requirements (have been doing some searching and seen the RB26 is approx 4.5 litres with filter).
But hard to get a straight answer through research on the internet (Some people have oil coolers or add extra for track days?).
either way will work for your car.
RB26 sump is 5.5 lt (i have one in my gtst and I use 6lt)
Just a thought.
http://www.skylinesaustralia.com/forums/topic/205993-transmission-lubricants/
Click me.
Stock sump GTR, just fill to the middle of the hump. From memory its about 6-6.5 litres. Have done in my GTR for the past 5 years.
Due for an oil change and was ready to buy some royal purple 10w40 for my 34 GTR (completely stock with 83k on the clock).
After reading through some of this thread, not quite sure if the viscosity i've chosen is the best choice?
Huh? Most of the thread has a consensus towards 10w40 and you're feeling unsure about your choice of 10w40 :wacko:
The problem with formalising it like that, is that no one can agree on the best brands/types/capacities.
This is where I say for the 11tyth time, you cannot kill your engine by choosing the wrong viscosity. There are no wrong viscosities, or right viscosities. Only more suitable and better feeling. Try a couple of different grades and see which you prefer the feel of (cold starts and hot running). I try a different brand and a different viscosity nearly everytime I do an oil change (5,000km) and my engine is running as strong as ever (very healthy RB25).
On another note, have been running Syn-X-6000 (Sougi 6000's replacement) in my RB25 for the last 300km. It's a synthetic 5w40 and so far I'm very happy with it. Feels just like Sougi, but a little smoother when cold, which I'll attribute to the 5w. Now for the test of time :)
I ended up trying the Castrol Edge 5w-40 and have to say im quite impressed. Motor does sound quieter than the Royal Purple 10W-40 i was using at cold start. I have a batch of Motul 5W-40 for the next change to see if the different viscosity was the contributing factor to running smoother when cold. On a side note most of our mornings here are under 10°Cn and getting colder.
I'm warming to the idea of trying some Syn X too. I don't think a 5w40 vs 10w40 is going to be that different at the end of the day.
Could someone give me an idea what to use in a RB25DE?
Going to run Redline Lightweight Shockproof in the gearbox, any idea what to put in the diff.. Standard HCR32 so i believe it has the viscous LSD? (yes rb20det was swapped for rb25de)
Preferably Motul as that is what i have the easiest availability too.
Edited by Crayske
yeah i read alot about sludge but from spending all day at work reading up on it it's like one person has said it and the rest have followed ..?
who has actually used it and had any problems? what is in magnatec that isn't in other semi synth oils that can be pinpoint to creating sludge,, i just dont follow..!
in saying that after reading up im more inclined to not swap the 10w60 castrol edge sport in both my rb25 and rb26 to the magnatec i just figured visco is about right and at $25 a bottle (normally $40 i must say) it seems an option
i have been using magnatec in:
2007 corolla from 30k to 100k! changed every 10, comes out relative clean for car of its age, no sludge.
1997 prelude for 25k - the engine has chronic piston slap but hasn't got any worse since using this oil - no sludge
1992 bmw e30 - maybe done 1000kms since we bought the car but can't see any problems yet..
i'm about to put it in old mans hiace with 220kms on the clock.. he's also thinking of switching from penrite and buying a dozen bottles of magnatec!
if its truly rubbish then yeah ill give it a miss but seems its all heresay
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
