Once my engine Is running at normal operating temperature, the 40 grade feels great...I wouldn't want to or need to go any thicker unless I was tracking the car. Engine temps are very consistent even after a thrashing. Again, it won't kill your engine to run a 10w60, but the 40 does feel smoother IMO.
Yes I would recommend Syn X 6000 for an RB26. I have been using this oil in my RB25 the last 5000-6000km and it's been good. Much the same feeling as Sougi 6000 had. About due for an OCD change, though there would be plenty of mileage left in it if someone wanted to stretch for the 10,000km.
Had some experience with Royal Purple API 10w40 oil, ran it for 11000km in my rb26 on a single shiite fram filter (noob mistake) and the oil was still light to mid brown, admittedly the motor was fresh but the oil was still relatively clean and the pressure was still 3.2 bar at warm idle, 4 bar cold. No oil analysis just my personal observation for what its worth. Currently running RP HPS 10w40 with a K&N gold HP2008 oil filter, car seems very happy.
I'm using Gulf Western Syn-X 6000 in my NM35 Stagea; I reckon is very similar to the Sougi S6000 that I was using previously.
$150 for a 20lt drum; what more can you ask for? Basically getting the 4th change for nothing.
before my local Autobarn stopped selling it, 8100 was around $80 / 5l.
I did a LOT of reading on oil before I did my first oil change in my new car - the Royal Purple seems to be good due to high levels of ZDDP in the HPS at least, however their marketing claims have been called out as BS numerous times on the BITOG forums. Also hard to find and pricey unless buying from a workshop.
Spotted RP on the shelves at Supercheap the other day
Must be everywhere now because this was in Launceston lol
Remember at the end of the day it is just oil, at $80 a change you could afford to replace your stock r32 motor every 37500kms instead.
Gotta weight up how much it is actually worth spending on oil.
Where the hell do you guys get the Syn-X 6000 from? Supershit/Autoshit/Repco doesn't stock it...
Prob a GW distributor?
http://www.gulfwestern.com.au/GW_nearest_stockist.html
not 100% accurate as i can get it in Tas but they don't list the people i use (Independent oils in Ulverstone)
I live not too far from GW head office in the 'Riff.
You pay for it, & they make you go and get it of the racking in their warehouse...
Worth it.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
