Once my engine Is running at normal operating temperature, the 40 grade feels great...I wouldn't want to or need to go any thicker unless I was tracking the car. Engine temps are very consistent even after a thrashing. Again, it won't kill your engine to run a 10w60, but the 40 does feel smoother IMO.
Yes I would recommend Syn X 6000 for an RB26. I have been using this oil in my RB25 the last 5000-6000km and it's been good. Much the same feeling as Sougi 6000 had. About due for an OCD change, though there would be plenty of mileage left in it if someone wanted to stretch for the 10,000km.
Had some experience with Royal Purple API 10w40 oil, ran it for 11000km in my rb26 on a single shiite fram filter (noob mistake) and the oil was still light to mid brown, admittedly the motor was fresh but the oil was still relatively clean and the pressure was still 3.2 bar at warm idle, 4 bar cold. No oil analysis just my personal observation for what its worth. Currently running RP HPS 10w40 with a K&N gold HP2008 oil filter, car seems very happy.
I'm using Gulf Western Syn-X 6000 in my NM35 Stagea; I reckon is very similar to the Sougi S6000 that I was using previously.
$150 for a 20lt drum; what more can you ask for? Basically getting the 4th change for nothing.
before my local Autobarn stopped selling it, 8100 was around $80 / 5l.
I did a LOT of reading on oil before I did my first oil change in my new car - the Royal Purple seems to be good due to high levels of ZDDP in the HPS at least, however their marketing claims have been called out as BS numerous times on the BITOG forums. Also hard to find and pricey unless buying from a workshop.
Spotted RP on the shelves at Supercheap the other day
Must be everywhere now because this was in Launceston lol
Remember at the end of the day it is just oil, at $80 a change you could afford to replace your stock r32 motor every 37500kms instead.
Gotta weight up how much it is actually worth spending on oil.
Where the hell do you guys get the Syn-X 6000 from? Supershit/Autoshit/Repco doesn't stock it...
Prob a GW distributor?
http://www.gulfwestern.com.au/GW_nearest_stockist.html
not 100% accurate as i can get it in Tas but they don't list the people i use (Independent oils in Ulverstone)
I live not too far from GW head office in the 'Riff.
You pay for it, & they make you go and get it of the racking in their warehouse...
Worth it.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
