Oh noes, I must have spun heaps of bearings by now then. I have been using Gulf Western products for 3 years now with hundreds of dyno runs and track work.
Considering 10 w 40 is thicker than the factory recommended I am sure it will be perfectly fine. The same can't be said for a w 60 like edge unless you live on a racetrack, and it won't save your bearings.
But oh noes, you blew an engine and you were running GW so it must be shit....
also, head gasket performance is now related to oil quality
They will have gulf western on their shelves in the next 2 or 3 weeks i was told.
I contacted gulf western directly.
They're very helpful. You can pick it up from them in Penrith NSW.
edit:
Just to add - a few days into it now, a few WOT squirts, cold starts, warm traffic idling, and general all round use, and I'm loving this oil.
If it performs till the next oil change (and from all reports, it should easily handle my standard 5000km intervals), i'm a happy camper.
Edited by Munkyb0y
Enough of this bitching. I want gukf western syn x 6000 Repco and autobarns only have 3000 Anyone have a good online source for this?
imo synx 3000 is heaps good if you're changing at 5000km.
and your car is stock.
but your car isnt. so good luck on finding 6000
Edited by xALmoN
3-4 years unopened i think, and if you're storing them in a cool dark place, even when the seal has been broken, it shouldn't matter that much, since its all pumped into a bottle from the storage tank anyway, no vacuum sealing and things like that, just the cap and seal.
edit:
Syn X 6000 will last you to 10,000km if you really want it to. If it's a daily driver and you don't thrash your car everytime you go out, then you can draw a full synthetic out to 10. I am like you though, in that I like my 5,000km intervals. By then the old RB has made any decent oil very black!
It is a very good oil, I ran it for 5,000km during my last interval. For those who don't want to fork out for 6000, there is 3000, which will do just as good a job.
Yes, thicker oils create a thicker/stronger film between moving parts...the oil has to get in and out of there in the first place, though. Thinner oils are generally better at circulating an engine with tight tolerances and servicing an overhead valve train. The key is striking a balance between the two!
Most engine wear happens during cold start up and cool down - 10w60 and 10w30 are the same thickness on start up, so out the window with a lot of theories about viscosity choice being responsible for engine failure. I've said it many times before: you can't really go wrong with viscosity choice...there are only suitable and more suitable grades. More important are regular oil changes and that it comes out filthy black!
Speaking of filthy and black....
The inside of my motor is that but the oil is still clean
So thinking a mild detergent diesel oil to clean it
Anyone reccomend a diesel oil for a turbo petrol engine?
Planning to change it out after <1000ks
Unless your engine has been rebuilt recently, the filth isn't necessarily a bad thing...it is now one with the engine and probably keeping things nice and quiet :thumbsup:
All RBs are dirty engines, they produce a hell of a lot of carbon, which is why the better oils come out pitch black after only a few thousand...so I wouldn't stress over it. Unless you have engine issues, the only cleaning you need to do on the inside is to use a decent petrol oil. The GW petrol oil products are fairly detergent heavy, so maybe whack some Syn X 3000 in there and it'll do all the cleaning you need.
For the record, any diesel oil with an SH/SL/SM rating appearing after the diesel rating will work in a petrol engine.
Shell Rotella T6 & Mobil Delvac 1 both in 5w-40 provide very good additive packs and are run in several petrol applications with good UOA results over on BITOG
difference between the 2 primarily is Delvac 1 is a group IV PAO based synthetic & Rotella is a Group III Dino - if you're running it only for a short amout of time the Rotella will be fine
I'm currently using Delvac 1 in my Forester EJ255 Turbo (wrx motor) after the great results posted up on BITOG
Rotella can be bought here
http://stores.ebay.c...u/GL-Lubricants
Delvac 1 available here
http://lubesdirect.com.au/
Edited by squareznboxez
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
