Oh noes, I must have spun heaps of bearings by now then. I have been using Gulf Western products for 3 years now with hundreds of dyno runs and track work.
Considering 10 w 40 is thicker than the factory recommended I am sure it will be perfectly fine. The same can't be said for a w 60 like edge unless you live on a racetrack, and it won't save your bearings.
But oh noes, you blew an engine and you were running GW so it must be shit....
also, head gasket performance is now related to oil quality
They will have gulf western on their shelves in the next 2 or 3 weeks i was told.
I contacted gulf western directly.
They're very helpful. You can pick it up from them in Penrith NSW.
edit:
Just to add - a few days into it now, a few WOT squirts, cold starts, warm traffic idling, and general all round use, and I'm loving this oil.
If it performs till the next oil change (and from all reports, it should easily handle my standard 5000km intervals), i'm a happy camper.
Edited by Munkyb0y
Enough of this bitching. I want gukf western syn x 6000 Repco and autobarns only have 3000 Anyone have a good online source for this?
imo synx 3000 is heaps good if you're changing at 5000km.
and your car is stock.
but your car isnt. so good luck on finding 6000
Edited by xALmoN
3-4 years unopened i think, and if you're storing them in a cool dark place, even when the seal has been broken, it shouldn't matter that much, since its all pumped into a bottle from the storage tank anyway, no vacuum sealing and things like that, just the cap and seal.
edit:
Syn X 6000 will last you to 10,000km if you really want it to. If it's a daily driver and you don't thrash your car everytime you go out, then you can draw a full synthetic out to 10. I am like you though, in that I like my 5,000km intervals. By then the old RB has made any decent oil very black!
It is a very good oil, I ran it for 5,000km during my last interval. For those who don't want to fork out for 6000, there is 3000, which will do just as good a job.
Yes, thicker oils create a thicker/stronger film between moving parts...the oil has to get in and out of there in the first place, though. Thinner oils are generally better at circulating an engine with tight tolerances and servicing an overhead valve train. The key is striking a balance between the two!
Most engine wear happens during cold start up and cool down - 10w60 and 10w30 are the same thickness on start up, so out the window with a lot of theories about viscosity choice being responsible for engine failure. I've said it many times before: you can't really go wrong with viscosity choice...there are only suitable and more suitable grades. More important are regular oil changes and that it comes out filthy black!
Speaking of filthy and black....
The inside of my motor is that but the oil is still clean
So thinking a mild detergent diesel oil to clean it
Anyone reccomend a diesel oil for a turbo petrol engine?
Planning to change it out after <1000ks
Unless your engine has been rebuilt recently, the filth isn't necessarily a bad thing...it is now one with the engine and probably keeping things nice and quiet :thumbsup:
All RBs are dirty engines, they produce a hell of a lot of carbon, which is why the better oils come out pitch black after only a few thousand...so I wouldn't stress over it. Unless you have engine issues, the only cleaning you need to do on the inside is to use a decent petrol oil. The GW petrol oil products are fairly detergent heavy, so maybe whack some Syn X 3000 in there and it'll do all the cleaning you need.
For the record, any diesel oil with an SH/SL/SM rating appearing after the diesel rating will work in a petrol engine.
Shell Rotella T6 & Mobil Delvac 1 both in 5w-40 provide very good additive packs and are run in several petrol applications with good UOA results over on BITOG
difference between the 2 primarily is Delvac 1 is a group IV PAO based synthetic & Rotella is a Group III Dino - if you're running it only for a short amout of time the Rotella will be fine
I'm currently using Delvac 1 in my Forester EJ255 Turbo (wrx motor) after the great results posted up on BITOG
Rotella can be bought here
http://stores.ebay.c...u/GL-Lubricants
Delvac 1 available here
http://lubesdirect.com.au/
Edited by squareznboxez
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
