I have absolutely no personal knowledge or insight - but googling around it looks like it could be a lubricant additive in your oil - http://www.bobistheo...e-oil-analysis/
Titanium
Titanium is a newer, more environmentally friendly anti-wear additive being implemented due to more stringent emissions regulations, and is phasing out the older, more harmful phosphorous compounds such as ZDDP (Zinc dialkyldithiophosphate). ZDDP reduces the effectiveness of the catalysts in catalytic converters by creating a plating effect when combusted, and covering the catalyst while Titanium does not. Titanium chemically binds to wear surfaces creating a hard, Titanium based oxide layer which reduces friction, thereby reducing wear. Concentration levels vary greatly depending on oil brand.
Looking a bit further, I found http://www.exxonmobi...UsedOilEval.pdf which talks about oil analysis, and mentions some negative reasons for titanium in oil tests:
Upward movement of Iron and Titanium and Chrome may indicate a spinning bearing outer race if the engine case is Titanium.
Don't think this is relevant for RB2X engines.
The last reference I found at http://www.lube-tips.com/focus/2006_08_30.htm
The presence of titanium in used oil analysis is generally a result of contamination from paint. This is often expected from new or rebuilt components such as gearboxes. Titanium can also result from wear of high alloy bearings, or high-quality steel in gears.
Anyway, hope I've found something useful.
Recently brought a 32 GTR, Fully rebuilt around 20,000k's ago. What oil would you recommend? Daily driver. Last service i put 10-50 motul in it.
Mobil 1 oil, always used it in mine from day one, never noisey, never changes colour, and no oil consumption, its impressed me, even with 300kw and ethanol its like honey on the dip stick... its 0w/40w
I thought having oil staying clean meant it wasn't cleaning the carbon/shit out of your engine?
i think thats more to do with your oil being contaminated by your blow by gases, so if your engines loose you'll have black oil sooner, mine would go dark after a number of dyno runs, but not with normal use...
im sure ill be corrected, now with ethanol it never gets dirty so must prove my point, but its still a clean oil whatever grade it is and has worked well for me.. my opinion only
Wat?
Mine is jet black after 500ks, sounds like there is no detergent in the oil.
Soot and carbon buildup are a byproduct of the combustion process, if the oil is still honey colored after 5000km then there is 2 possibilities I can think of. The engine is extremely clean by engine health (good compression etc) and the tune itself (not overly rich etc) or the engine oil by design has minimal detergents for cleaning
As said before, every engine and setup must contribute heavily then... The engine has close to 200k on it, comp test 175average, zero oil consumption and definitely a rich tune, people driving behind must be getting tipsy lol, hope theres no RBT around as i drive by, they'd all be taken into custody..:)
I would of thought the soot was from the 98 having being made from oil products, ethanol is an alcohol so how can you get soot? it should literally clean the soot out the tail pipe?
  • 3 weeks later...
lol at the tipsy comment.
I've found it doesnt matter what i put thru my car, it used to always come out almost as clean as it went in after 5000km. but with time and some more Km's (almost 80k ive put on it now, total of 145k) it is getting a little dirtier every time. but still by no means black or even a solid color.
My angry old bug would turn the oil black within 2 mins of running after a change :P
I've now gone to the Penrite Ten Tenths, racing 10, 10-40 (stupid name). ive never used penrite before, whats everyone's thoughts? (ive done this due to availability in my local area.....im getting sick of chasing round the countryside look for the same oil everytime)
reported to be very good and for a non 300+rwkw skyline that's not seeing the track is a great choice
whatever the engine builder reccomends
Your oil getting black is from the detergants 'cleaning' your engine, you certainly wouldn't want to be getting black oil just from blow by.
If you change oil only every 5,000km's it should be slightly black, by 10,000km's if it aint black I would be worried, either the engine is impossible clean or the oil aint cleaning sh*t.
I chnged my oil today and noticed that i used the whole 5l bottle but i couldn't see the oil covering the cams is that meant to be so i read a post where someone said they only use 3.4l.
It's a NEO engine .
Edited by B-rice
Blowby is one of the reasons oil needs to contain detergents to 'clean' the engine.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=258648
If ring seal was perfect and combustion was complete, oil would last far longer.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
