Valvoline brown bottle?
yeah brown bottle, it has good compression 200psi across the 6, goes well but bit of blow by and a constant dull piston rattle/slap, was thinking bout putting a loud muffler on put probably still hear it.
think ill try a 20w - 50w then, any good ones or anything do for the taxi motor lol
  • 3 weeks later...
Here's a decent video for oil nerds. Valvoline engineers, but not too salesy. Unfortunately, they don't really set Eric straight properly about synth not causing oil leaks, and give him an out with a corner case. His cognitive dissonance shows.
https://www.youtube.com/watch?v=FXqkOZAkXZw
yeaha thats true, but im pretty sure Nissan recommends the Matic D for the Atessa and the power steering as well so it might be worth just getting the one 6l bottle of that since i found one for $70
There's a lot of D compliant stuff around, but you may as well just get the Valvo since its well priced, and use it in the PS (and for me in the Stagea's auto since its meets J as well).
Nulon Synth ATF (C D J K) 66.50/4L = $16.60perL
Valvo Synth ATF (D J K) 49.95/5L = $10.00perL
Transmax Z ATF (D only) 76.50/4L = $19.10perL
Any brand will work fine, some just last longer than others.
I still believe you are better off using a cheaper ($50) oil and changing it every 5k rather than spending twice that and trying to string your changes out to 15k.
  • Like 3
Just got some $16 Shell 10w40 oils for my next 2 changes, come to think about it I've being using sub $30 oils for ages... :woot:
how often you change it with oil like that?
also what mods you have and what sort of work does the car get?
Changed every 5000 km/6 month, car just has the usual bolt on mods (TBE, FMIC, POD, boost tee + SAFC II) running ~10psi on stock turbo.
It was just used as a daily driver (auto) for the past 4 years & now my mum uses it mainly for work runs.
I should add they are still semi synthetic oils (Shell HX7), the ones I used before were GW Syn-X 3000 10w40 which was about $28/bottle.
Edited by Mayuri Krab
  • Like 1
Just thought I would give a bit of info on my experience. Fully forged rb26 with 7 or 9 litres sump (sorry can't remember) and oil cooler. 30,000 km on the engine, oil and filter change maximum every 5000. Only ever used Penrite HPR Diesel 15 Engine Oil - 15W-50, 10 Litres for about $78. Had good experience with this oil in my LS2 so stuck by it. Anyway had a noisy turbo bearing so decided to check the sump. I was pretty happy, here is a picture of the crank untouched. post-89815-14097450987776_thumb.jpg
I think the oil did it's job quite well and diesel additives kept it nice and clean. I forgot to take a picture of the sump but there were no deposits or discoloration, perfect.
Btw turboworld said the turbo bearing cage issue had nothing to do with the oil as the bearings were perfect.
Oil pump was also pristine.
Hope this contributes to the knowledge base. Thanks
Edited by XGTRX
Bit off topic - but what was the cause for the bearing failure?
The bearing cage on -5s have issues I was told. He showed me the bearing and it was like brand new. He was impressed
And wow thats crazy clean, but being 15w-50 isn't that a little thick? 15w seems a bit thick for cold start.
In theory I suppose but never had an issue on both cars, LS2 is a stock bottom end using this oil for about 100,000 kms, rb26 is forged so I get piston slap when it's cold anyway because of the increased piston to bore clearance, so cold, the thicker oil wouldn't be an issue I suppose. But I never push it until it's up to 70-80 degrees. Edited by XGTRX
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
