Ryco is a good brand
I use the drift filter, because they have a magnet built into them which I cut open and check every service even though I know the bearing are not metal lol
Diesel oil can be used in petrol motors but not a good idea for petrol oil in diesel motors and not a bad idea for performance motors, I used Castrol magnetic diesel oil for the run in on my RB2630 then switched to Brad Penn 10w40
  • 3 weeks later...
From what i recall from ppl who have cut them open Ryco are just ordinary budget filters. From what's available in Australia, K&N are supposed to be good. Generally OEM filters are good, so i'd imagine Nissan filters would be a good option too.
I done a search and couldn't find a post about this - https://www.ozbargain.com.au/node/163258
Can anyone comment whether Castrol Edge 5w40 would be good for a Nissan Skyline V36 350gt?
Edited by Leon.T
Should be ok, but it looks like its a dino so dont push the OCI. DI motors (is yours VQ35HR?) often contaminate the oil with fuel more than non-DI so shorter OCI on a dino is not a bad idea anyway. What does the owners manual specify? Make sure it meets all those requirements.
so is nulon's touted 'fully synthetic' range actually hitting that mark?
it's so hard to work out what is and isn't actually fully synthetic because the line seems to blurred
You will have to send them an email and ask. This is one of the reasons why I use Penrite, all info is available on their website, they even tell you about the additives used :thumbsup:
Edited by Missileman
If it says fully synthetic on the label, it must be fully synthetic or they're in breach of the consumer/fair trading legislation.
Fully synthetic can mean either;
Group III - hydrocracked mineral oil (there was some argument about whether this should be considered synthetic when it came out). All the cheap synthetics will be mostly Grp III.
Group IV - POA (or the new Gas to Liquid oils) eg Mobil 1
Group V - Esters eg Motul 300V or Redline.
running a lucas race 20w50 where can i get this type of oil from brisabne area or something the same of another brand
Unless you have a problem with oil pressure, i'd think about Penrite 10-Tenths Racing 10W-40.
That should be "Unless you have a problem with oil pressure or temperature" and temp should be <120 degrees.
  • 1 month later...
What oil would be best for a gtr32 with a built motor? Previous owner was running Shell 10w40 semi synth with changes every ~8000KMs. Car is mostly street driven with the occasional midnight run (only driven couple times a wek). Is a semi synth and 10w40 ok? Recommended mobil is 5w30 thoig for a standard motor
anyone use moly-chrome 10w-40, i just put some in the Ls1, its very clear and clean looking compared to the penrite oils that have a darkish look straight out the bottle, autobarn guy said its german and good stuff.
Do you mean Liqui-Moly 10W-40? Its German and well respected. Don't judge an oil by its colour. You can't draw any conclusions from colour. For example. oil that looks black after use may just be doing a good job of cleaning the motor's insides.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
