  • 3 weeks later...
So as far as oil goes I have a few questions with Oil Pressure?
I live in AZ where the summer weather is 110-120 degrees F.
I drove my car in California where the Oil pressure was FINE. but as soon as I came back to AZ (where I actually live) the oil pressure started to drop. Drop meaning almost to 0. then only getting up to maybe 20-30psi driving. Does Crazy hot weather have an effect on that?
Because in California like i said the oil pressure was fine because the weather is significantly cooler there 60-80 degrees F.
I'm running 20w50 (switched it on 7/6/2015 when I came back to his pit of fire called AZ)
from 10w30
I thought since it's too hot here the viscosity is thinning out too much with 10w30 but even with 20w50 it's still dropping...
Is that a ambient heat issue? I'm going to try and replace the sending unit and if that fails too then I'm almost sure that I'm going to need a new oil pump which is going to cost me quite the bit of money because of Labor. (I don't have the time to be doing my own engine work ATM)
Thanks for your input guys!
1989 HCR32
RB20DET
Only engine mods done are FMIC/Intake/ Turbo Back.
It happens after normal and hard driving.
I do not have an Oil Cooler installed :( I was hoping if it was a temp issue then I can just get a Oil Cooler and call it a day.
I'm replacing the sending unit this week.
I'm just hoping that it's not my oil pump and worst case scenario gap in my bearings :(
Edited by HanBear
I don't have an oil temp gauge and I really do not know oil temps too much
My back ground on skyline experience is little to none. I've only had the car for about 3 weeks. I have a water temp guage and it usually sits around 70-80 according the guage. If that means anything. :(
I replaced the sending unit. The z32 sending unit was indeed a perfect fit and now my pressures are fine. You guys were right. And I was lucky that's all it was. For now.... I haven't driven too much on it yet so I'll see how it goes. Thanks for all your inputs.
This thread is sort of useless.
Some people drove to the shops, some track their cars.
Without full information you can't make a call on the reccomendations.
Spot on Ben, if anything it shows that it kinda doesn't matter as long as it's within a reasonable weight range and changed at reasonable intervals
When you've got a track GTR running magnatec and road cars running the most expensive off the shelf oils you can buy, it really comes down to personal preference
I feel the same way about the tyre thread. Particularly since I've had several sets of tyres that felt great when new (and hence get good reviews) but when half worn felt like you were wrestling an angry and well-lubricated pig. Truly good tyres maintain their grip level right to the canvas (but obviously not the water-clearing ability).
  • Like 1
The tyre thread is as useful as a toothbrush made entirely from ants.....
You get people who have used one tyre ever giving it 8/10. How on earth can they rate if if they haven't used other tyres on the same car ins the same conditions as others? Useless thread.
At least with the tyre thread you can get some who compare two different tyres (but may be comparing old to new), and there can be some use in that. In this thread people use engine sound or oil colour or no evidence at all to say an oil is good/bad. So its pretty much just a mix of stuff they heard from somewhere, confirmation bias and cognitive dissonance.
Also, its way more important to make sure that you don't empty the sump than to choose oil X or Y, because even the cheapest oil lubricates way better than air.
  • Like 2
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
