Hey Guys,
Just Wondering if the Gtr is Really that much better than the GTST? Ive herd you can do the 25 to outrun the 26 which I dont believe but maybe their is a GOD out their! :) Some of you think this is a stupid question but I would just like to know other peoples thoughts! Who know's It may well be close to the GTR's performance! :)
  • Replies 268
You can always make an engine out do another engine, it all just depends how much money you want to spend. So yeah you can make a RB25 more powerfull than a RB26, you can also make a SR20 more powerfull than a RB26, it all just depends on money and what you are willing to put up with.
Putting the power to the ground.....well the GTR has that one over the GTST every day of the week.
Some of you think this is a stupid question...
Not stupid, but talked about on SAU before. You should be highly conscious of your driving style and what you demand out of a car, before you yourself, could answer which one is better for you.
32gtr vs 32gtst - worlds apart
33 or gtr vs 33 or 34 gtst/gtt - can make similar power, but gtr still has superior everything.
drifting your thing? the rear wheeler is for you.
the thing about owning a gtr is you can pretty much be smug in the fact that without much effort you can easily slaughter pretty much anything on the road including the exotics
Edited by Betz
You're comparing chalk to cheese. GTR and GTST are very different cars.
GTR is always a better performer. Only exception is drifting :)
One plus for the GTST is that modding it is cheaper, but it'll always be trying to catch up with the GTR unless some big dollars go into it.
this is an intresting question. i curently have 250rwk in my 33 gtst and i think would do quite well against a gtr with same power on a rolling run.
off the lights the gtst dosent stand a chance though
the gtr is also going to be better if its wet, or anything that resembls a corner and even uneaven road surface.
Yeah nothing compares to a full on GTR launch...but I guarantee if you keep the ass of the gtst soft and spend some good money on tyres they'll hook up off the line just fine.
Problem I see with many gtst's is the owner. They pump $$ into horsepower then skimp on tyres, makes no sense at all.
R33GOD, u must be insane to think u could take on a gtr of similar power...
similar power isnt what allows u to win.. its how that power gets down and delivered that matters.. i ran a 230rwkw s14 when my gtr was only makin around 200awkw... we did both rolling and off the line
i slaughtered it. not just beat it.. i slaughtered it.
why?? probably because i had a shitload more torque than he did
u dont see same 1/4 figures from similarly powered vehicles either... i could easily reel off an 11sec pass... ud struggle to get 12s because of traction. even ur trap speed will be much lower...
2 completely different cars.
off the lights the gtst dosent stand a chance though ^^^
i dont wheelspin on a rolling run :)
but u cant automatically assume the gtst isnt as good on the run. just dont understand... i have 630nm torque at the fly, and aren't the gtst's much lighter than a 33 gtr?
Edited by R33GOD
they are lighter... but so is a s14.. even lighter still and 630nm @ flywheel??? cool
ive got 813nm @ wheels
i think thou, the reason for the torque levels isnt so much the capacity, although it does play a lil part, its the amount of air the twins flow compared to ur one single... get me?? like could be similar PSI but in actual air volume, its greater on a twin.
thats all i can come up with
ok. are you running 250rwk though? cause i stated similiar power
i think we're gettin off topic
i think in almost any situation except driftin lol the gtr is far superior
it has better brakes, better handling, better tractabilty, greater potential, better seats lol
it all depends what u want from a car... ive always loved the gtr, but i never bought one earlier (got mine in august) because its not what i wanted yet... i had to give other cars a go first
p.s: sorry that 813 was when i made 287kw... @ around 250kw which is only 30kw less, id probably have over 700nm @ wheels
Edited by Bumblebee
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
