  • 1 month later...
  • Replies 221
  • 1 month later...
Trying to do this mod at the moment but cant get the rb25 exhaust housing apart from the centre. Got the bolts undone no worries, have tried heaps of wd40 and manhandling etc but it refuses to budge, any ideas?
  • 2 months later...
  • 1 year later...
  • 1 year later...
Aren't you scared of the ceramic wheel shattering? Hell they do that at around 200rwkw and 12psi boost.
Also, So you are leaving a decent gap between the exhaust impeller and the housing..that is inducing lag/inefficiency isn't it?
Just a couple of thoughts but the results sound great.
So you are still using the very small exhaust wheel. Interesting
And you didn't get it balanced with the new compressor wheel??
Edited by benl1981
  • 6 months later...
Yes the Gap induces lag
It was balanced
Your calls but honestly the 6/12 bladed T04B compressors or even possibly 16/18/20G late IHI compressors .
I have not seen one in the flesh but there is a newer IHI type turbine in the Trust catalog called TD06HSL2 , its a bit more like a Garrett GT design and if available in the normal rotational direction and suits the Hitachi diametre wise could be good .
This turbine in reverse rotation form is supposed to be a ball tearer and in the Evo Green 20G (20G-LT) on Mitsy 4G63t's .
They are (LOL) a factory integral gate twin scroll turbo and the crazy yanks are screwing 450 GG's out of them at high boost on good fuel . Note Precision Turbo US is using their unique 5/10 blade 20G reverse compressor wheel in it
Attention Roy , if your still into TD05/06 turbos GT Pumps here in Australia have those T06HSL2 turbines . They are smaller lighter less blades and higher flowing than the garden variety TD06H turbine so if interested in RB20 turbos worth a call .
Pics Top is TD06HSL2 turbine , lower LHS in FP's 5/10 blade compressor , RHS is the 60mm NS111 turbine (TR30R turbo) that the #@*+'s at Garrett wont gives us - yet .
Cheers A .
Edited by discopotato03
Cheers A .
lol, disco you were actually my first point of call for any new idea's on a newer more efficient and surge resistant compressor wheel.
The new style turbine wheel looks like the ones used in the GT-K Turbonetics Turbo's.
Edited by BOOSTD
After a couple of hours, I have the T04S 52 trim at the top of my list. In comparison to the T04Vtrim I last used, It has a reduced surge zone, is more efficient at the low boost that I will run and will fit into the std compressor cover. I may look at the GT30R ported cover if there is a chance it will fit. I'm sure i'll get a better results in its native cover.
Comments?
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
