I remember being in the sad bus with Bill Pye in 2009 (Wrestpoint) and he was telling us he'd spent over $350K on building that thing of his.
Not to mention he has punted the thing off a 100 times, hate to think what the repair bills would be like!
I guess it keeps Grant in a job though!
....... and you got good money for it, so suck it up Princess!
...... and start building a GTS-t :D
Well a hug or a cup of harden the f**k up. Thanks woo. Have dried my eyes. All good. Really need to find out what all the fuss is about with GTST. :)
Was your car really 1100kg? someone said they saw it on my105
I will make no comment on the cosworth stroker crate motor but the car weighed near enough to 1260 at race weight. I weighed it after targa with a bit of stuff out of it at about 1245
Drive mine anytime mate.
They're fun to drive, cheap, quite quick, sound great, did I mention cheap? :)
it was a 3l cossie job wasn't it? :P
the bloke running round telling everyone it 1100kg is renowned for making stuff up
Ah, the truth is finally out there about the engine. :)
Yeah, he is definately talking shit. Feel free to pass on the pic of the weighbridge piccy below. Not tat it actually proves anything as the car isnt in the pic.(SMS's it to Snowy to wind him up) :) I think it weighed 1270 at THC when they put it on the scales. Have nothing to hide so would happily confirm the weight if it was 1100kg. In reality the time attack guys with fully gutted cars struggle to get to that weight. Dont hink I have actually ever heard of a 6 getting that light. maybe 1150...
and Woo, you had me at cheap :)
Hmmmm. I think i have some idea of where the 1100kg might have come from. My service crew may have been guilty of adding some grist to the tassie targa fraternity rumour mill. :) Apparenbtly there was some chatter about my car when it was for sale and Greg got queried on it. When asked the weight his response was something along the lines of "I cant remeber if it was 1100kg with or without the crew in it." :) Farkin shit stirrer.
Greg loves a shit stirr!
But I had it on good authority from a guy that knows a guy who knows the guy who built the motor and its definately 2.4 grunter.. well that was the talk sunday night at the bar lol!
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
