It's in BABY! (Costanza)
I was about to pull it off the hoist, had run it a few times and was literally cleaning my hands, when I noticed a drip..... One of the new welsh plugs we put in began leaking, the bastard one behind the thermo housing area.
So, I was deflated when I realised I'd need to pull the engine out to fix it, but I decided it's a 20, so run it for a while and surely it stopped leaking.
Just need to bolt some panels back on it and we're back exactly where we were in October of last year! haha
I'm getting too old for this shit.
My wife just asked me how good my life insurance was as even she can see how stupid from an OH & S point reducing the number of tyres we have to use is. Or was that just her rubbing her hands together?
Edited by CycloneGTR
Warren has made it through with only 4 Dunlop D03 M's for the last few years. He just got a bonus 2 spares this year. I don't think a limit on tyre numbers will do much for speed.
The only people it's going to hurt is older 2wd cars
Edited by sav man
Oh farking blah blah blah then! haha
IMO and always has been, for Big Targa anyway, they NEED to allow 6 tyres purely on safety and duty of care grounds. With the event getting longer, it's simply dangerous to have people of bald, illegal, against the law tyres when traversing the wet west coast.
Pretty simple really. and I'd be completely amazed if they reversed their prior rule.
having said all that though, I enjoyed the challenge of getting through on one set...... it added another dimension to the competition :)
Edited by Marlin
Personally, if I was still runnning the EMO I would be happy with a 4 tyre rule as it seemed to be very easy on tyres and we could have easily got through on 4 this year. And it certainly does add an extra element taking a gamble on what you believe will be the fastest tyre that will get you to the end, manage your tyre wear during the event and also punt on weather conditions.
But for the general field, I have to agree with Woo, unless the scruits are stopping them, guys will press on to the wet west coast on tyres they have gambled badly on that have been shagged on 3 days of dry in the east, hit standing water and have bad things happen. Despite the fact we didnt need them, we chose to fit fresh fronts just before hellyer (and the rain as forcast by TT's mothers brothers local fish and chip shop owner in Strahan :) ) just cause it couldnt be a bad thing. Fresh sharp edged tread tyres always offer up more grip in heavy water and having a car that will steer and is maybe a bit taily is always going to be better than understeer of fail into a rock wall or off an embankment. :)
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
