What are the problems with the DR30 rear end? Is it the camber change like a 1600?
Not sure what to do with this car till we get it and see what spec it is? It ran LMS in 2001 so that would be very close to SS now. Eventual plans are for full MS build incl S13 susp and steering, RB cr g/box, serious llightening etc. Might run in an event or two as is and see where to go from there.
I saw there was an Escort in the ocean on that 2001 Targa Tape, is that the same spot as the 2 cars at Wrest Point?
Talk to Ken at Accurate Suspension 3808 2878, he has heaps of Datto experience and races one. There is a BMW 2002 that he has worked on, similar semi trailing arm suspension, which hauls axe at Lakeside, search Mr Dickie for a recent vid on YouTube, seems to handle great. As a bigger buck alternative there is always MCA of course for the best suspension, I'm sure that Murray Coote has Datto experience. With the right work the STA suspension is pretty damm good eg E30 BMW..
Good luck, keep us informed :)
Found the Mr Dickie vid
The thing is, the BMW suspension is no better than the Datto's, the difference is that BMW owners will spend money to get it right.
Edited by 260DET
I like it!
And that red steering wheel will match your lipstick......
I prefer my lipstick black Benny cause I'm always sad..
Thanks for that, I hadn't thought of Ken. My wife knows him pretty well, they spent alot of time racing each other around witches hats when they were littler! I will drop in and and see him for a chat. Murrayflex (MCA) will be the preferred option eventually. Murray and Dave Feron have done quite a bit of work "developing" the 1600 rear ends over the years.
I don't really know too much of the specs of what suspension is in it already (Koni?)? Find out when it gets here I guess..
Might have to do a few laps of Lakeside to see where it is at?
Not all of us get no pants Friday! But I got my team trophy in the mail last night.
I've looked through my engine, and surprisinly the cam snap didn't put any shit through the engine, or damage the cam caps, or bend any valves! So that's a win.
Here's Mt Arrowsmith, good way to waist 30min on a Friday
How much longer are Mazda going to persist with the RX8?
Mazda is giving it one last run I think later in the year.
I heard the 3 MPS is for sale?
And given it's pants-off-Friday I have much better things to do with my time than watch 27 minutes of you and Damo huffin n puffin ;)
My rebuild is coming along. Cage, paint and most of the wiring is done, engine & gbox should be out this / next weekend and off to be screwed together in the coming weeks.
FIA padding makes for a comfy elbow rest while rebuilding!
I am going Snowy River Sprint at the end of the month.. Not 100% confirmed (IE not flights booked) and not sure what car yet though...
That FIA padding, why don't we just zip tie a brick to the cage probably be softer!
Personly I think showroom should be as the car rolled off the showroom floor, with a cage, ecu (to stop limp home, speed limiters...etc), basic shocks/springs, and possably the mufflers cut out so they sound better.... like the frogmobile
I can't go into Mazda and get a 3 MPS with front floating Brembo's, and a Kaaz diff. I can see why Octagon gives the consessions out to fix the road cars problems, but it's getting away from what showroom was a couple of years ago.
Benny its with Danny Traverso, seems like a good bloke and got a good crew. Either in an Emo 9 or a GC8 2 door. The weight is on Burkey's shoulders to give the IX the ready to race tick of approval!
Timmy that sounds cool!
We ran Showrrom back in 2005 (and won it I'll add!). Back then it was stock shocks, ECU's, mufflers etc, ... everything. Only mods were pads and tyres. That was tough getting cars through then, but unfortunately, the category didn't have the "cache" it attracts now.
I dunno where I stand on it. Depends if I run a Showroom category car anytime soon I guess! :P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
