just jap sell these. buy it through them on here, you'll get a good price.
i had one of these. they are ceramic inside. good price, average performance. they dont compare to a proper stainless internal high flow.
Edited by Munkyb0y
in my old r33 gtst and 32 gtr i cut the sensors off cause i couldnt get it out of the stock cat lol.
causes no damage if thats what your asking.
the way i see it (since they werent built track/race cars), i dont need a sensor to tell me my exhaust is hot lol
mmm my exhaust sensor wire got cut a while ago, the light in the dash came up and the check engine light eventually came up too. I've heard it doesnt affect anything but the lights in the dash annoy me and i want to get it fixed.
I'm hoping i just need the wires soldered together.
that isn't xforces high flow model, tho it does flow pretty good. it is a ceramic core
there is a higher flow metallic item, which flows upwards and over 800cfm depending on size
http://www.skylinesaustralia.com/forums/Fo...nc-t206716.html
Edited by Angus Smart
I was very dissapointed in mine, going from a gutted cat to this, because I have a white car and the carbon monoxide that normally gets filtered by the cat was turning my rear bar yellow that I had to keep cleaning off...
I used it for 20 mins, car was jerky and laggy, now have it sitting in my room... Im going to spend the cash and get a proper high flow metal cat....
It does well for me. Very noticable upgrade over a standand cat (which i had on with my turbo upgrade)
I was looking for a metal cat but wanted one bolt on and couldnt find one, so i went with the Xforce, and it still did me well :) A lot less lag and generally more power throughout the whole rev range
how can you tell if it's a metal cat? stainless steel exterior?
metal cat, the brand?
or just a metallic cat in general?
a metallic cat has a metallic core inside, instead of ceramic.
looks something like this
Edited by Munkyb0y
I just upgraded my exhaust to an xforce system... noticable difference over stock lol... as for cat i havent used a metal cat so have nothing to compare it too.
Although the temp sensor didn't fit into the cat!!!! I had to take it to a chop shop for them to drill out the stainless steel hole a little wider then it screwed in nicley lol.
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
