I don't class a minute or two with a flat file as "machining", it's not like I used the lathe or the mill or even anything electrically powered. Quicker and easier than cleaning your teeth. If someone told me that they weren't capable of that simple a filing job, then I sure as helll wouldn't trust them to bolt on a set of brand new rotors, pads, callipers and braided lines.
Yeh that looks after the pads, but what about 343mm rotors that becaome 340mm with the correct hat offset. No drama if you can do it or can get it done....but the drama of payign people to do this stuff adds to the cost of a compromised solution, i say compromised as it gets towards a full kit price. ... i am just making excuses for wanting a straight up bolt on guaranteed to work well solution :thumbsup:
  • Replies 133
I know the sizes i want, front 17 x 8.5 +30, though i am not sure how they work with brake calipers ?!?!?!?
The wheel pictured is 17x8.5 +40 offset which just clears the custom coilover struts on the inside.
Yeh that looks after the pads, but what about 343mm rotors that becaome 340mm with the correct hat offset. No drama if you can do it or can get it done....but the drama of payign people to do this stuff adds to the cost of a compromised solution, i say compromised as it gets towards a full kit price. ... i am just making excuses for wanting a straight up bolt on guaranteed to work well solution :cool:
I guess I am the engineer and tester (ie; guinea pig) for what eventually will be an off the shelf solution. Complete package, BO + GTW for half the price. But it needs field (ie; track) testing to prove the results, temperatures, G forces, braking distances etc etc. When I break (no pun intended) down the "Chinese" kits I find that the callipers are worth next to nothing, which confirms the physical observations that tells me they are compromised in design, manufacture and the hardware supplied. Their lifespan is questionable and servicing comparatively costly and sometimes impossible due to long term unavailability of parts. Compared to what is a very decent standard calliper, they have no real advantages and lots of disadvantages. Except bling of course.
Cheers
Gary
Yeah, not impressed about the dollar! The guy I was ordering through has not responded for a week... which has cost me another few hundred. Not happy Jan.
The price landed was $2050 US for the 332mm kit. The 355mm kit was $2700 US landed.
I'm just considering a few options at the moment, but I think I'm just going to get the stoptechs through another supplier. I'm also in some talks with another guy about piecing together a custom 4 pot Brembo monoblock kit, so we'll see what works out as the better kit.
Just thought I'd give an update.
I ended up going with my first choice of brakes, which was CSC. I'd always said that was the setup I was going to go with once I decided to upgrade, and thanks to a lot of help from Stuart at Benson Motorsport (t01-100 on here) I picked these up last night.
So now the brake setup is CSC 4 pots with 343mm discs, 33 GT-R rear brembo calipers, and a BM44 Master Cylinder with the ABS blanked out, set up for use with no booster. Should be plenty for my lil' old 180SX :(
I've not heard a bad thing about them thus far, so I'm glad I went this way. I've heard really good things about the Stoptechs too, but I like the local support of the Bmax/CSC's and supporting an Aussie brand. And if they're good enough to pull JFK's car up, then I'm sure it'll be heaps for mine :blink:
What didn't Matt like about his?
Same thing I've heard about Stoptechs, in the rare cases I've seen that people haven't been happy with them. Perhaps a set up issue? Loose wheel bearing? Who knows, but hopefully I don't have the same issue!
noice! GTRJason on here has them on his 32 GTR. that thing has some serious power, (well over 400awkw) and dog box etc and the times I've been in it it really pulled up nicely. he has been able to run 17s with them too.
Ok, so now we just have to find a nice 1 pce std sized rear rotor that uses curved vanes and is slotted/fish hooks etc.
Stoptech dont make OE replacement rear rotors, Endless and Project U are all straght vane. DBA and RDA are shit! I think i may just end up getting some Endless rears unless someone knows the part number for the AP rotors. I know they exist, but nobody lists them. I suspect that perhaps they are N1 diameter so ???
Yeah, I spoke with BB last year about them and he gave them a really good review. They're on some really quick cars and have local support, so I'm really happy about picking them up.
Troy: Are you sure mate? Aren't 300ZX rears the same size as yours? I'm getting a price on CSC rear discs as well, not sure if they're curved vane or not though.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
