Hey Guys
Went to WSID on saturday, chucked some drag radials on and unfortunatly i had to leave my Just Jap G4 coil overs in which are hard as a rock when drag racing.
First run 11.5 @ 129mph
Second Run (turned boost down 6psi less and stuffed the start with 2.4 60 foot) 12.3 @ 126mph
Third run 11.3 @ 130mph.
My best 60 foot was on the third run 1.845.
With some stock suspension i should see a mid 10 hopefully!!
Had my big Skylinesaustralia.com sticker on the back window and was the only jap car i saw there the whole day.
Power level is about 500hp at wheels on 25psi and 20psi on second run was about 420hp.
Anyone got some stock suspension in sydney they can sponsor me with? :blush:
https://www.sau.com.au/forums/topic/228992-guilt-toy-runs-113sec-at-130-mph/
  • Replies 90
Johno, i sent you PM back. cheers :blush::(
Nah boost controll kit did not fit my PFC :( i can mod the plug to fit though i have just been lazy.
Yeah doof with the drag radials it didnt want to spin at all. no traction issues man it just took off...
I just need to get some stock suspension and and go back :)
Some nice numbers there, you certainly have the mph for a good ET. 1.845 60' isnt too bad, if you take 0.2 (1.6) off this and times 2 , you should take a further 0.4 off your ET giving you a high 10.
Yes... i should be able to get a 1.6 60 foot which will see me do a 10. but i need different suspension first
Nice! Is it 2.5 or 3litre? Cams?
3 litre with stock cams and stock rb25 head. DEAD STOCK.
Is this thing normal weight? Thats a pretty sharp time.
Those 60 foots should come down a lot also. How many psi were you running in the tyres? Are they MT ET Radials?
Yes normal weight, had back seats in it and floor mats in it.
I must admit mate
thats some good mph and time
congrats
i take back what i said months ago :)
hope you get your 10, the mph is there for it:D
Lots of people are eating their own words mate.. its all good. i knew what the car had because i was driving it around and was terrified with that power on the street
Congrats, with all the work and effort you've put in over the years, that must have been a sweet result :)
Keep the updates coming!
Oh, and BTW - don't turn down the boost, just turn it up!!!
Cheers mate, its been a long time comming, i just had to wait till everything was right before i took it to the track.
Well Done Mate.
Geez I would be happy with 11s let alone a 10...buuuuutttt......Lets see an RH9 gtst!!! That would surely piss off all the snotty nosed GTR owners around here :D
Yes it would upset them, but i would need a 1.2 60 foot to get a 9 and that is not going to happen... maybe with the water meth injection kit switched on, but i dont need to do a 9.. i just want a 10
Awesome result from the 3ltr Guilt-Toy. And its still meeting emission requirements?? :D
Won't be able to push much more than 500wrhp out of the GT35.... GT40 TIME!!! :(
at the time of the race it still had the emissions tune in it, but it had a screamer pipe and a race pipe (no cat) and the catch can was vented to atmo, 15 mins worth of mods would see it back to emissions compliant.
Remember this car gets over 400ks to a tank of fuel as well :)
So yeah not bad for a car that i did mostly myself (bar the fabrication work)
thanks for the comments guys, il go back down very soon.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
