Just thought i would post some pics of my R33GTR circuit car. I am still in the process of building it but am starting to see some light at the end of the tunnel. Have just got the car running and am running the new engine in at the moment 40klm's so far but still plenty of work to go. Build time so far has been around 18 months. Specs are as follows.
1995 R33GTR non vspec (dont let the sticker fool you)
Interrior: 6 piont roll cage, Cobra suzuka seat, 6 point Willans harness, Seabelt seuade wheel
Suspension: Tien super street coilovers with EDFC, Whiteline front and rear sway bars, Whiteline front camber kit, Tien adjustable castor rods. Hicass will be deleted. This suspension set up will get some attention as soon as the budget permits.
Brakes are currently Brembo F50 front calipers with 355mm rotors on flaoting hats with ferrodo ds3000 pads and standard brembo rears with project mu pads.
Engine: N1 engine block, HKS step 2 2.8lt stroker crank, HKS rods, HKS step 2 2.8lt piston kit (different pin height), full Tomei metal gasket kit inc head gasket,inlet manifold,throttle body,exhaust manifold,turbo & dump pipe,
Head has been mildly ported and fitted with HKS inlet and exhaust cams 264 10.2mm & 272 10.2mm respectivly, Tomei type B valve springs and retainers, Tomei cam stud kit, ARP head stud kit, HKS cam gears, Nismo timing belt.
Hi Octane modified sump with a custom dry sump set up running a peterson 5 satge pump 3 pickups from the sump and on off the back of the head, Peterson 3 gallon oil tank, ARP main stud kit, ACL race series bearings, N1 water pump, Tomei exhaust manifolds, HKS gt2530 turbos, Hks adjustable waste gates,HKS hard piping kit, Tomei 3" dump pipes, Custom front pipe twin 3" into 4", Full 4" exhaust.
Fuel system: standard fuel pump used as a lift pump custom serge tank, Twin Bosch 044 fuel pumps running thru two -6 delivery lines and 1 -6 return line to a HKS fuel rail, Sard 700cc injectors am currently undecided on wich brand of fuel reg i will use either a Magna fuel or Turbo smart
Cooling: ARC 120mm intercooler, ARC swirl pot & Breather tank (not yet fitted), PWR custon radiator cross flow 75mm core with inbuilt water to oil oil cooler.
Drive train: Is currently running a standard 5 spd gearbox with ATS carbon twin plate clutch. This will be swapped for a Getrag 6 spd (R34 gear box) with Ats carbon twin plate clutch a one piece carbon tail shaft as soon as the engine is tuned and will also be looking at fitting a ATS 1.5way front diff as soon as the budget allows.
Electronics: Running the engine in on the standard computer injectors and afm's at the moment will be fitting a Motec M800 ecu as soon as I have enough klm's on the engine with motec boost control. Ruzic engineering (user name mountain runner) series 2 engine monitor, Ruzic engineering Race logger (in beta testing now) and will be looking at fitting a Ruzic engineering 4wd controller once the data logger is fitted so i can maximize my set up.
There is probably a heap of other stuff i have forgotten but as like nearly all race cars it will be constant and ongoing deveolpment. All work on the car apart from the roll cage and exhaust fabrication has been done by myself in my shed out the back without the help of any sponsors so has been a long hard slog and kept me poor but am starting to see some light at the end of the tunnel and is starting to make all the hard work and sacrifice worth it.
https://www.sau.com.au/forums/topic/231223-dazmos-r33gtr-build/
  • Replies 148
Risking I am running filters in all the scavage lines before the pump and also the one in the boot before the tank although the filters that peterson supply will not stop any bearing material going thru the pump if you happen to have a catastophic failure but the pumps are very resilaint and need to have some fairly large size schrapnel go thru them before it will damage them. The filter in the boot before the tank thou if much finer and will catch any bearing material (hence the size of it so as not to impeed flow) should you ever have that problem. I will be doing betwwen 500 and 1000 klm's on the engine before the ecu is fitted and in sees a dyno.
Looking great Daz !!
should be ready to rumble real soon
Will be coming for a trip up to your place this weekend sometime mate will get some k's on the thing and take you up on that drive of the R35 :banana: . The missus has the weekend off and is hasseling me to get up there and suss out your new beast for herself aswell. Will definatly sell her on the idea and get me off the hook for a purchase down the track :P
nice work mate, looks like a clean well thought out setup :P i see you have gone without abs aswell, makes the engine bay look alot cleaner without all the hardlines and unit in the corner.
Makes everything a lot easier to work on as well have been keeping my eye on Mark & Duncans build as well and there is some talk about removing the booster to get a better more consistant pedal feel. So will look into this aswell seems like just a bit of fiddling around to get the right pedal ratio as at this point I am not really considering a pedal box. This may change down the track if a better brake upgrade is done but first i need to finish it and let the bank balance recover :banana:
Great work Darren....if I didn't want my car to still do a blast down a public road this is what I'd be doing to mine :P
Interesting that you are considering putting in an R34 box....speak to Snowman (Andrew) for details but he found out the hard way that the R34 box can be fragile and that the R33 ratios are better for track use....in fact his R34 track car uses R33 running gear now.
No the R34 gearbox strength is fine - I just didn't like the ratio's in the 6 speed. For what I do the 5 speed works better.
Carry on.
very nice mate! Looking good. Will be good to have a run with you at the track when its all ready. Looks like it will shit out some good times too :down:
Hopefully it will do some good times I think the car will be more than capable just not to sure about the driver :google:. Will definatly be heading out to a few top gear and JDM meets once it is finnished. Is it your/your old mans car that is getting a rebuild at the moment in another r33 thread ?.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
