Couldnt see a thread so thought I would start one, thanks to Ash for organising the cruise today. Met some new people as with most SAU events and had a great time despite the weather. Amazing to find Lauren's parents from 20 minutes up the road from my parents place back in the UK!
Thanks to Mav for co-piloting also :rolleyes:
Will upload some more tomorrow, off out now.
A few pics:
https://www.sau.com.au/forums/topic/233079-gor-wrap-up-thread/
Great cruise!
Thanks Ash for organizing the cruise, good work.
Car felt and performed great on the road, even in these wet conditions. Big thanks to EAS Performance for an outstanding job :rolleyes: Was so happy to be behind the wheel again!
A few people with cameras, so don't be shy and post up pics :)
Well I had a fun day. Shame about the wet weather on the way home but now I can say I've at least done half of the GOR.
I'm glad I got my hands on a CB. Much better when you know what's going on. Al. Your Evo is sick.
There are some pics here. http://www.skylinesaustralia.com/forums/Go...80#entry4087187
I didn't see the wrap up thread.
photos are uploading to my gallery now. should be another hr or so till im done. been capped you see. anyway. i've played round with a few pics with the levels and contrast but cbf processing them all. my fav pic of the lot would have to be Al's headlight. came out a lot better than expected. all the shots taken on the road are courtesy of my passenger. i was too busy having fun
Gallery 1
Gallery 2
pics are jumbled too soz
Great day out :D
Pity about the weather on the way back, but oh well, nothing you can do sometimes!
Thanks for coming everyone... i must thank Aaron @ rampant & Mick @ Micolour, without thier help thurs/fri i wouldnt have been able to take my car :bunny:
Top blokes both of em!
I'm kind of pissed about this... despite having signed up to SAU Vic on 4 August, I STILL haven't been given access to the Vic club events forum and couldn't get the details. :D
Sorry Max, I've given you your access today, i didn't have a spare moment late last week.
FYI - As the Membership form states and i did inform you, please allow 15 business days for processing.
So 4th Aug + 15 business = 26th Aug.
26th Aug would be 2 days from now :bunny:
Thanks.
Ash
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
