nah wont be dropping it.
The roads around my way are a joke.
Cant even get in the servos around here as it sits.
I had a EiBach lowering kit but sold it ;)
cheers for the kind words guys
I got the Eibach springs on mate, car looks great - Ill have to get some new pics up as soon as it stops raining so I can wash it :down:
Hey guys,
Have added a couple of bits to the car. Took some photos with the iPhone, so excuse the quality of the pics:
• CF Rear Diffuser
• US Battery Cover (to cover the right side of our engine bay)
• CF Hood Hampers
• Eyelids
The USA G35 forums say that the cheapest version on Ebay is a POS, but the more expensive one is rather good fitment and look. From memory the cheap one is around US$200 + shipping and the god one is US$400 + shipping.
After a good two months of waiting for my order to be shipped. My Inven front bumper for the coupe finally arrived from the U.S. Will post pics as soon as its fitted with my impul sides.
Edited by CRISP 35
I got the Eibach springs on mate, car looks great - Ill have to get some new pics up as soon as it stops raining so I can wash it :thumbsup:
good to hear. :thumbsup:
I would have loved to use them but have trouble at the stock hight.
Cant wait to see some pics
^^^ looks great .... what are the width and offset of your wheels?
thanks for the comments.
19 x 9 +22 (F) on 245/35R19
19 x 10 +22 ® on 275/35R19
no rubbing but then again i haven't dropped it and i travel light. read somewhere here that the max width at the rears to avoid rubbing was 9.5" at +22 but the extra rim depth was too tempting.
Thanks for the info. I bought my LMGT4s in 9.5 +20 and the fronts are perfect but the offset on the rear is sadly lacking. Once I lowered the car it severely cambered in (and looked very shite), so I got some SPC rear camber arms, and the alignment workshop brought the camber from 4 degrees back to about 1.5 degrees. Looks a bit better now, but I definitely agree with your 10 +22s on the rear - I am going to buy a pair of 9.5 +12 or 10 +15s for the rear of my car to make it look better. In fact I am going to try some 20mm bolt-ons for a car show this weekend, so we will see how she runs with 9.5 +0 :wacko: - I will post pics next week. Note too I am running a stretched 215 on the front and 235 on the rear (I like the drift look), so will get no rubbing.
Nice wheels :wacko:
My 9.5 +18 rears, wearing 275 wide tyres, were VERY close to scrubbing. In fact one of them was scrubbing until i had the camber adjusted (using the factory camber bolt).
I've since had my guards rolled and dropped the car even lower. I'm now suffering the same problem as nightcrawler. It has caused additional camber and the wheels tuck-in too much, looking much crapper than before.
My plan of attack is to eventually fit some spacers and slightly stretched tyres (245 maybe). Night crawler, if you could throw up some pictures of your setup with 20mm spacers, it would be really appreciated.
Thanks for the info. I bought my LMGT4s in 9.5 +20 and the fronts are perfect but the offset on the rear is sadly lacking. Once I lowered the car it severely cambered in (and looked very shite), so I got some SPC rear camber arms, and the alignment workshop brought the camber from 4 degrees back to about 1.5 degrees. Looks a bit better now, but I definitely agree with your 10 +22s on the rear - I am going to buy a pair of 9.5 +12 or 10 +15s for the rear of my car to make it look better. In fact I am going to try some 20mm bolt-ons for a car show this weekend, so we will see how she runs with 9.5 +0 :banana: - I will post pics next week. Note too I am running a stretched 215 on the front and 235 on the rear (I like the drift look), so will get no rubbing.
no prob. your set up looks great judging from the track pics you posted and the wheels look hot. front is perfect already and putting on the spacers at the rear should bring it out to match it. looking forward to the pics.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
