Nice front bumper crisp, i felt smart and imported mine from the states too, impul 535 cs. almost broke the bank, worth it though, although i too will never do it again. shame i have to sell the car soon..
Thanks Djog yes it is worth paying for something that is rare. Shame u did not get impul sides as well that would have looked killa wid urs. I made sure i got impul sides they go with almost any front bar. By far my favorite side skirts. The pics i put up don really do justice 2 how they look in reality. Anyways pitty ur car has to go mate. GL.
Well I took a good friends V35 out for a run on the weekend as he never uses it. Here are some photos of it up in Jindabyne.
Now it’s time to sell the thing to buy another project we can use on the track. But I must say it’s a very nice car to cruz around in really enjoyed driving it.
Hope you like the images...
Now it's time to sell the thing to buy another project we can use on the track. But I must say it's a very nice car to cruz around in really enjoyed driving it.
damn that looks way better then mine. i need to know where your mate got the front fenders from. i like.
The front fenders are made by the owner of the car Steven at Prestige Motorsport Aust. based in Lansvale Sydney, stock guards just cut and a R35 GTR Badge moulded in and the black mesh fitted behind.
If you are from Sydney you can go have a chat to him im sure he will make up some more if ther is some intrest out there for them.
hey kuek, the r35 rims offset looks pretty awesome man. also digging the front smoke headlights, did you so the back also?
thanks richard, yea back has the overlays as well.
Looks Good Kuek. Is that da supacharged v?
yup, its the old VDIRTY5, have had a full forged engine rebuild and getting tuned this week
Looks good with the 20 inch R35 rims. Just need a cf hood to finish off the look.
tempted but i don't want to give cops a reason to give me a yellow for
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
