On 5/10/2017 at 2:03 AM, Girorostar said:
Any more info on the setup?
The kit is made by a company here in the states called Momentum Performance,They went out of business a few years ago. Its a GT35r, V band plumbing 600cc injectors. ETC. Ive changed up a few things, Im running a custom SFR intercooler a little more airflow friendly to the sedan bumper and the Cosworth plenum.  Pretty happy but im ready for more boost.
https://www.z1motorsports.com/forced-induction/momentum-performance/momentum-performance-single-turbo-kit-350z-g35-p-4875.html
  • Like 1
  • 3 weeks later...
On 02/11/2015 at 8:25 PM, colin.ssc said:
Mine was done by Leo. He's from Sydney area. Wrx and liberty guys use his services heaps. Let me know if you want his contact details.
Hey mate have you got Leo's contact details?? Definitely interested! Thanks!
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
2 hours ago, LesF said:
On the day I handed over my Z :4_joy:  and drove this home.  2010 370GT fresh off the boat, seems to have been looked after nicely by the previous owner(s).
Jealous about the Red. I tried for months for a Red SP v36.
got a boring white in the end
  • 1 month later...
My 2010 V36 250GT. Live in Tokyo, enjoying the TV tuner while driving. :14_relaxed:
BBS style rims
Tanabe Sustec Pro Coilovers
And in future some dark window tint at the back. And thats probably about all I want to do with her.
  • Like 1
  • 4 weeks later...
C7608573-4354-47F7-8310-F9B238BCA4A2_zpsGot the 10.5's on the rear finally.
F--19x9.5 +38 with 10mm spacer. 265/35/19. Pss tires
R---19x10.5 + 30. With pretty decent pull 285/35/19 pss tires
also put my vent visors on.
Edited by BoostedSedan
  • Like 2
 So this is mine
V36 with R35 GTR rims
245/35R20 on the front
255/35R20 on the rear
Bent the rear bumper bolt mount up so it wouldnt scrub on the rear.
Fronts could use 10-15mm spacer but nothing at the moment
  • Like 1
  • 1 month later...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
