mythbusters ahoy!
standard powerfc
FUEL CUT on REV LIMIT (which is set via hand controller) (or datalogit) - there is no other way to adjust it
powerfc pro
SPARK CUT on REV LIMIT (which is set via hand controller) (or datalogit) - there is no other way to adjust it
+ also with launch control
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4166359
ok well i did it, i set it to 6950 last night.
two things.
1. even tho it was set at 6950 it still spiked out to 7215rpm when i hit the rev limit hard. is that normal?
and
2. Does it hurt the engine or anything bouncing it off the limiter?
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4167152
do you have to turn car off and back on again to get the settings to stay in?
i've not fiddled with a power fc for a while
tho maybe not true, as i remember sitting at lights and adjusting the launch control (gti-r) and that changed right away. now there was a few funny looks from other motorists, Bang bang bang bang!
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4167209
No
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4167443
if the engine couldn't rev happily to 8000rpm they wouldn't have put the factory rev limiter there.
So what I said about the factory limiter being at 8000RPM is correct?
Why the hell lower it to 6950 then!!! It's CRAZY TALK!
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4168053
ive been told that 8000 is way to high and should reali be kept around 7000revs... so daily i wouldnt need any more then that.
Just being safe..
On a daily car, it is fine.
On the race track, stick a bit lower down. (This is why the ex bathurst GTR ran a 7000RPM limiter on race day, but during prac/qual ran 8000RPM...)
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4168121
also dude, if its your daily, how many times in a day are you going to be bouncing off you rev limiter?? im sure you will give it a squirt here and there, and if you do, having you rev limit at 7500rpm is fine, even 8000rpm! but just dont sit there and bounce, obviously then you asking for trouble. with these motors, in first and second you still pull when hitting 6500 - 7500 or so, so if your changing gears early, then you wont be inside your torque range in the next gears.. and so on...
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4168137
so your saying hitting 7000rpm on a daily basis is fine?
Is this a trick question or a very silly one?
Not sure... so im gonna reply with one of my own
You sit on the limiter daily driving?
No.
So of course its fine for a daily driver.
Bouncing of a 7k limiter would be FAR WORSE than reving the car to 7500rpm and changing naturally.
You often come here with some misinformation, so wherever you keep getting it from, you need to stop going there or talking to that person.
7500rpm would be FINE. However, are you making power there on the stock turbos? Probably not that much so changing from 7k-7.5k would be the spot
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4168229
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
