The British Police have had many many performance cars over the years particularly different counties where street racing etc was more prevelent. ^^
That "photoshopped" Evo doesnt look too disimilar to how I would expect one of the FQ range to look out of the UK. :(
  • Replies 40
Posted Images
Why is Dezz the only one here who gets it?
P R O M O T I O N A L
MMA supply the cars, some drunk guy with Paintshop does the decals (apparently) and the Hammers use these cars for city and central urban traffic duties.
Why? They stand out, people look, people see POLICE.
Same way people sticker up Smarts or Hummers (or Aston Martins) - so they are noticed and seen.
My brother was in charge of marketing for HSV when they provided the GTO to VicPol.
There was no cost at all to the Police - it gave HSV a chance to have their car seen (and talked about) and for the Police to have something flashy and prominent to help create a visible presence.
Expect to see this car heading up booze busses on St Kilda Rd, running traffic support for public events, and pulling over people on mobiles driving through the city.
Alan - MMUK FQ cars already out:
http://www.edmunds.com/insideline/do/Drive...rticleId=125124
If you truly were awesome, you'd want a drive of the Superleggera.
Its like f*cking the sexiest chick in the world while you watch and high-five yourself at the same time - then someone kicks you in the kidneys, and the cycle begins again.
Left Autosalon on sunday as we got to the lights we saw the evo x cop car so we sped up, we finally got next to it and the cop puts down his window and goes hey boys what you think? we put our thumbs up said looks fkn sick man! we talked about the car for a while and he said its the best car he has ever driven and that he cant believe hes getting paid to drive it then when the lights turned green he floored it back went down off they went leaving a trail of smoke had to be the best cops i have come across so far since i have been driving they were just smiles and were happy to be out there and were not dick heads. We need more of these cops on our roads with an appreciation of Japanese cars!
see how happy ppl are when they dont have to drive around all day in a commodore?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
