Not everyone running ethanol is a tightarse, some run it because its a better (higher octane) fuel, Holden are banking on people running it for no power increase, just to make you feel warm, fuzzy and green. It has worked out around the same cost as 98 for me per km, but with a much higher power output.
I run ethanol because I hated the sound of my engine pinging on a hot day, I wanted to run stupid boost, and the 30% extra torque was a great bonus. Plus much of my hard earned is staying in Australia, some even going to our poor farmers.
Is there a better fuel you can buy from the pump?
Dont get me wrong Im not against it I run e85 and im the last person that gives a shit about consumption as I constantly drive on boost getting prob 250km to a tank which I dont complain about, what im saying is that the people that are saying its cheaper then petrol thats its not quite right just cause its 20cents cheaper a litre but as I said I went on it for the gains of power and safer on the engine as you said
Filled up a Jerry at Caltex Footscray but it was very slow!!!! They told me they had fuel but the pump was stuffed. Going there later to try and fill up, otherwise its back to 98.
The Springvale pump does the same thing, just hang it up and start again. It seems to do it when they don't enable the pump quick enough.
I've been searching the web for a while regarding e85 into a rotax Kart engine.
i'm about dew for a full rebuild on my motor and wanted to give e85 a go before i do so..
the carb has fixed jets, that re changed by removing and replacing with larger/smaller jet
Heres a little bit of reading on tuning.. if someone could tell me what i'd need to do to get e85 going would be great :)
Next you will need to install the proper Main Jet for the current conditions. Remember that the proper main jet can only be determined by knowing all of the following conditions:
Temperature
Humidity
Barometric Pressure
Altitude
Once the Main Jet is installed and the carburetor reassembled, you will be ready to install it back on the motor. Be sure to tighten the hose clamps and that all of the bolts are tight as well.
Take the kart out on the track and observe proper 'warm-up' procedures. Once the engine is warmed up, begin pushing it to its limits.
LOW RPM TUNING - If the kart runs rough at lower RPM's (5,500 - 8,500), we need to adjust the needle setting to be 'leaner'. How 'rough' it is running should determine this adjustment. Never adjust more than (2) grooves in any direction, this can cause a low RPM seizure.
HIGH RPM TUNING - If the motor will not rev cleanly from 10,000 RPM through to 12,500 then change the main jet to ONE jet lower. For example, if you are running a 168 jet and the motor pulls well through 11,500 and begins to break up or bog at 12,000 you should change to a 165 main jet. If the leaner jet seems to help, but still does not feel 100% right, consult your plug reading to determine if a leaner jet is suitable. BE VERY CAREFUL. At this point, going too lean could cause an engine seizure. Once you have found the appropriate main jet, it is possible you may have to change the clip setting to eliminate any lower RPM bog.
If the 'leaner' jet does not remedy the problem, you should install a jet that is one size bigger (richer).
The indications of a jet that is too lean can include a loud 'popping,' or a sudden drop off in performance at high RPM.
Any time the jet seems too lean you should consider immediately coming in to the pits, getting a good 'cut' on the plug and reading your plug indicators.
try getting a jet literally 30% bigger than your current jet, then check AFRs or if not possible, check egt with a temp gun and compare to your current egt with petrol.
then once set try adding some timing and see how you go with it. you should try and have some way of testing the power, ie 0-100kph with petrol vs 0-100kph with e85 + more timing, let us know how you go
did another e85 test on the current batch of Caltex bio-eflex
http://www.mrparts.com.au/MPRacing/?p=460
Very interesting, thanks for the posting that. Wouldnt the United E85 (really E95) have issues with cold start in the winter?
I thought someone in this thread mentioned that Caltex have never gone to their summer mix and so far have just stayed with their low 70's winter mix? Did you get a chance to test Caltex during summer?
Flash point of Ethanol is 13deg and petrol around -40deg
By my calculations the flash point should be around the following...
E95 = 10deg
E85 = 5deg
E70 = 1deg
These are only approximate figures but they wouldn't be too far off. I know for over here in WA we could probably get away with E95 all year around as it only really drops below 10deg ambient in winter on cold mornings.
For colder weather like Melbourne you would probably get away with E85 all year around, E70 maybe for super cold mornings...
Realistically Australia has a fairly hot climate and there is no real need for winter mix (car may take a few more turn overs in winter) but remember they are selling to non car enthusiasts as well who may consider the extra cranking a problem/issue
Edited by SimonR32
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
