  • 3 weeks later...
Hasn't moved much from E65 since they started supplying. With ethanol in short supply atm I don't see them increasing the percentage anytime soon.
Get a $200 wideband if you're worried.
Just wondering...does anyone know the accurate percentage of ethanol of the eflex fuel at springvale and mt waverley caltex servos at the moment? Still don't have my tester...
springvale was down in the low 60's for a while in the dead of winter, but i fill up from Glen Wav for the last few months and have been back to Chequered for some touch up stuff since, content sensor was saying E70.
Actually, i should really get this all going on my laptop. Parallel desktop then Link software, then i can tell you EXACTLY what Glen Waverley is at the moment (filled up a couple days ago)
But to be honest, the two outlets should be the same as it's the same truck and delivers it.
off to piratebay.org...
we weren't sure if it was the Ethanol shortage from the floods that caused the real low winter numbers or if they were being ultra conservative from a cold-start point of view and hence have a higher petrol content.
What will be interesting is if they go to full E85 in summer, shall be checking the laptop with interest :D
I should check if Fueltown has their E85 back up as well...
Fueltown is still out according to my mate, he cant tune his old xr6 flash box anymore so is back on 98 until fueltown have stock of e85. He was running Caltex for a few weeks but it just ran too rich.
You would barely notice the difference between e65 and e70 on the wideband, I just assumed they mixed it on site as the tank was filled hence the inaccuracy's.
  • 4 weeks later...
Sydney Tempe site is now E80. I asked the servo attendant and he said 80%, then went home and tested and yup.
Can't wait till the car has the engine in and tuned! Have 40L of the stuff waiting in jerry cans hehe.
Q: Being it's E80 but knowing that Caltex will revert to e70 later on, do i ask my tuner to tune it slightly leaner or richer to compensate for the future change back to e70 that caltex will implement.
Unfortunately i only have a pfc so no funky ethanol content sensor here.
  • 2 months later...
hey guys
just want to say great thread, has been a mission reading it, only up to page 54, thought i would share something ive just read from another thread
just finnished reading a thread on detonation and pre-ignition, i come accross these two paragraphs and i remembered a few of you guys were running lower EGT's
"The other technique is a little more subtle but usable if attention is paid to EGT (Exhaust Gas Temperature). Detonation will actually cause EGTs to drop. This behavior has fooled a lot of people because they will watch the EGT and think that it is in a low enough range to be safe, the only reason it is low is because the engine is detonating.
The only way you know what is actually happening is to be very familiar with your specific engine EGT readings as calibrations and probe locations vary. If, for example, you normally run 1500 degrees at a given MAP setting and you suddenly see 1125 after picking up a fresh load of fuel you should be alert to possible or incipient detonation. Any drop from normal EGT should be reason for concern. Using the "Tin Ear" during the early test stage and watching the EGT very carefully, other than just plain listening with your ear without any augmentation, is the only way to identify detonation. The good thing is, most engines will live with a fairly high level of detonation for some period of time. It is not an instantaneous type failure."
as far as ive figured out E85 burns at slower rate therefore timing can be advanced a great deal more then PULP
it also had a higher Octane rating makig it harder to ignite
becasue of its high alcohol content alot more fuel is needed to compared to PULP to get your bang for buck, this in turn would keep cylinder temps down and reduce EGT's
Are the E85 guys missing something here and having their engines detonate without them knowing or is the low EGT's just a safe bi-product of E85?
My GTR was tuned on united E85 (and according to my ethanol sensor that is E 90). I have ran anything from united to Caltex 'flex fuel' over the last 12 months and never had a issue. Take that how you will, but that is my experience.
hey guys
I know from bikes that when you run an ethanol content your egt's are much lower that pulp, so its a safe bi-product of ethanol to have low egt, couldnt give you a figure for a car engine though. Its much safer on your valve seats and almost everything because (especially e85) is just so much cooler.. And in the case of a 2 stroke (getting off topic) its awesome if you tune it right, will make huge power difference and much harder to melt a piston
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
