Ive just had HKS SPL pipe kit installed on my car. I want to "hide" the pods. Im in the design stages for a cover but Im concerned that the pods may not get enough air. Do you think it will be OK If I go ahead with it?? I dont have CAI,etc.
HKS SPL Kit:
Design cover with sides:
Will enough air still get under the sides to the pods?? Should I go ahead with it??
Thanks
https://www.sau.com.au/forums/topic/239749-will-my-pods-still-get-enough-air/
There is still plenty of airflow, it wont be a cold air ram intake, but it wont be any worse than it is now.
Anyway air in the engine bay around ur pods is only really hot when the car is stationary
When ur moving the air is constantly being pushed out and replaced with cooler external air.
My bet is it wont make a difference, except for getting the cops off ur back about having exposed pods
post up plenty of pics of ur final airbox
Cheers mate, I agree with you, the sides I am putting on it arent that big so air should still find its way under them.
i have the same kit, cut a hole in the body work directly underneath where the pods are and run a 3-4" flexible intake pipe down to where the passenger side indicator is. i cut out the grill area on the indicator and the air goes up through that hole to my pods
still will get cop trouble as they arent enclosed, just covered on the top... as mentioned it wont be any better than without the cover, better to do something fully enclosed and have some air ducting, more costly, and time but better
Looking nice Bakes! Love HKS!
As ppl have said, it might not make much of a difference with the heat shield as you have the front mount intercooler.
BTW pods are ok as you are only alowed 1 intake mod, as I was told.
Do you still have the Standard Air Intake? You know the one that sits on top of your radiator? (Pic Below)
I suggest you just place the intake piece back on to feed air to the 2 pods.
Dont have the stock intake. Pods are defect in NSW.
At least this way they will be sought of hidden. Im not doing it as a heat shield, Im doing it so that the pods dont stand out like dogs balls.
Also I washed the car this morning and the pods got drenched. The cover should stop some water getting on them.
Ill go with the cover, If I get defected (touch wood I dont) Ill then get a custom enclosed box with intake done.
Yeah, I made it myself with 3mm aluminium plate and then covered it with carbon fibre contact.
Because I dont have any cold air intake I didnt want to make the sides too long, still need the air from the bay to get to the pods.
^^^^^ 1+ That's a great idea.
:P
Nice work Bakes.
Oh yeah forgot you were in NSW LOL!
Guess you can try a wreaker or Just Jap to see if they have any air intakes.
But when you said water got in when washing your car, Im sure air will have not problems getting in.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
