Garage Saurus carbon R32 for a daily, painted white. keep your 1000ps hi mount too, id go for low twins for tractability. (it is a run about after all :) )
For a weekender, (I) cant go past a 240z (first car i can remember saying to myself ''i want one!'')
silver,wantanabe's,caged,RB26,stroked,poked,you name it! :(
Dude you are F**king awesome!!! :D
Me and a friend were just talking about the 2 cars you posted last night.
Garage Saurus Carbon R32 GTR FTW and the 240Z with what you mentioned with black wide fender guards and carbon bonnet.
  • Replies 68
Dude you are F**king awesome!!! :(
Lol! yep, spot on, but i think id paint the bonnet!..... dont want to stand out TOOO much! hahaha
I see most of you don't read.
The request was not for an off-the-shelf dream car, but something that given the time, money and skill - you could build or restore for yourself.
I don't see too many people being able to fashion a Murcielago out of a log and a Repco catalogue...
Anyhoo, for me, it would be a 1973 Porsche 911 2.7 RS and ANY classic Ferrari.
250 Cal Spiders and GTOs are telephone number money, but a 250 GT Lusso or 275 GT still are in the realms reasonable fantasy.
1973 911 RS
250 GT Lusso - Steve McQueen's actual car
275 GTB
My Dream cars to own and restore or modify
Torana A9X
Porsche 550
Datsun 180B SSS with either a RB25DET or RB26DETT (just for the fun factor)
'71 Skyline GT-R
'58 Corvette (fully optioned - four speed manual, power windows, power top) - yes the manual was an option back in the day.
The 917/30 was the most powerful sports car racer ever built and raced. The 5.374 litre 12 cylinder (90.0 x 70.4 mm) twin-turbocharged engine could produce 1,560 bhp (1,160 kW) with twin turbochargers run up to full boost, a simply astonishing 39 psi, though it usually raced with around 1,100 bhp (820 kW) at 7,800 rpm to preserve the engine. The 917/30 dominated the Can-Am series during the 1973 season. The 917/30 could go from 0-60 mph (97 km/h) in 1.9 seconds, 0-100 mph (160 km/h) in 3.9 seconds, 0-200 mph (320 km/h) in 10.9 seconds, and on to a top speed of 257 mph +, (413 km/h +)
:P
Garage Saurus carbon R32 for a daily, painted white. keep your 1000ps hi mount too, id go for low twins for tractability. (it is a run about after all :D )
silver,wantanabe's,caged,RB26,stroked,poked,you name it! :P
+1 for the 240z, some one posted a one of a silver fully restored and done up to the max. with RB26 and everything.. and it looked absolutly amazing.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
