  • Replies 435
Posted Images
Can anyone recommend any other trailer companies (Sydney only) apart from; Austrailers, Unique Trailers, BM Trailers, Mario Trailers.
Based on my car specs (600kg, 2500mm wheelbase, 1500mm width, 3900mm length) i've had everything recommended from 10x6 to 12x6, single and twin axle and priced from $1800-$3000.
Richard,,,how the hell did you pick that so quickly,,,,Spot on my good man. Rod Marklands car actually.
Neil.
way too much time spent in the paddock at historic meets running the alfa :yucky: it looked very familiar!
It's so much fun fitting out a trailer,,,I'm having a ball!!!. 12 volt and 240 volt are going in next. I need to do a bench top but don't want to add a super heavy kitchen top so I'm undecide on than one at the moment.
post-29-1226822765_thumb.jpgpost-29-1226822798_thumb.jpg[attachmen
Here mine, brand new got it Friday..... I've been driving around everywhere with the 'line on it this weeknd just to see how it tows and find a balnce sweet spot ;)
Would have considered getting one via Bobby but this one was a lot closer to me.
Now the customising starts.... I think i'll kick off with 12V, running water, mount the compressor, tyre rack, tool box, and hopefully some through-floor ratched tie downs :D
Edited by Marlin
Marlin that actually looks like a trailer from 'Unique Trailers' (re: bobby) as its exactly the same design even down to where the plate is fitted also the sealed off inner guards which I havent seen on any other trailer except 'Unique Trailers'. They have recently opened a shop in QLD too and send them up from Sydney.
I spent about 4hrs trailer shopping on Saturday.
That exact design in 12x6 tandem with used rubber from 'Unique Trailers' is $2950 on road with flat or beaver tail. The build quality is very good and Peter was great to deal with.
'Austrailers' want $2800 on road for the same design in 12x6 but flat tail with side rails. They had 1 in the yard which looked like it had been there atleast a month as the brakes were rusted over and a couple of other little joins had started to rust (possibly just due to lack of paint prep in these areas rather than poor workmanship). I could have taken that 1 for $2600 cash on road but kept looking. The guy there was extremely helpful and they obviously know what they are doing due to the amount of stock they were pumping out.
'Elf Trailers' wanted $2250 for 12x6 + blueslip + rego + GST but to me it would be too much mucking around getting it blue slipped and rego'd when the other 2 shops offer the same design for basically the same price on road.
The interesting think I found was that due to the jigs they have setup for the standard car trailer sizes (12, 14, 15 x 6) that to get a custom made 10x6 single axel would cost me the same because it takes longer for them to measure and cut etc so i'll just get a 12x6 tandem and be done with it.
The biggest problem now is that I keep being told by neighbours and friends whom have owned many trailers to make sure it is galvanized if im not prepared to strip/paint it yearly if it sits out in the weather (which is something I definitely don't want to do). My trailer will only be used about 15x a year so their is no reason why it shouldn't ever look anything but brand new.
I'll have to ring Unique + Austrailers on Monday to find out pricing on galvanized to see what the price difference is. If it's only a couple of hundred i'll get it done but any more and i'll just get regular paint I guess.
Hi,
Here is my trailer that i purchased a little while ago, it is 15ft with electric brakes, ford hubs and 100mm drop axles.
Endend up being $4000 from B&M Trailers, they are selling the standard ones for $3100 which is 14ft a lot higher and cable brakes.
Mattpost-8233-1226827197_thumb.jpgpost-8233-1226827610_thumb.jpgpost-8233-1226827737.jpg
Replied to your PM Ben.
I got a 15ft version, I like to have some room and it might even be better come resale time.... the beaver tail is good, very easy to load and no fluffing about. :P
Edit: Oh, and the floor to guard clearence it 180mm, so my 32 has about 70mm clearance.
Edited by Marlin
Yeah it's charged by the kg so a trailer is pretty dear. The one I've got uses Blue Scope thick wall tube (not China crap) and is Hammertone finished, so honestly, it'll out-last me. Especially if I don't quite smoking soon.
edit: Changed "fagging" to smoking.... woulda left myself wide open.
Edited by Marlin
mmmmmmm fags......
ben, if you want the thing to last just keep it dry. as long as you can keep the thing out of the rain it will look sweet for ages. otherwise they look crap pretty quick. 1 or 2 outings in the wet and they get spots all over.
meh gal for sure if you can afford it. we paint ours every year or 2 (I don't know many people who have enough inside storage for cars, let alone trailers.
just imagine how much fun it is one weekend a year to be wire brushing, priming and painting a trailer when you could be building (yet another) motor for the race car instead
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
