  • Replies 435
Posted Images
Can anyone recommend any other trailer companies (Sydney only) apart from; Austrailers, Unique Trailers, BM Trailers, Mario Trailers.
Based on my car specs (600kg, 2500mm wheelbase, 1500mm width, 3900mm length) i've had everything recommended from 10x6 to 12x6, single and twin axle and priced from $1800-$3000.
Richard,,,how the hell did you pick that so quickly,,,,Spot on my good man. Rod Marklands car actually.
Neil.
way too much time spent in the paddock at historic meets running the alfa :yucky: it looked very familiar!
It's so much fun fitting out a trailer,,,I'm having a ball!!!. 12 volt and 240 volt are going in next. I need to do a bench top but don't want to add a super heavy kitchen top so I'm undecide on than one at the moment.
post-29-1226822765_thumb.jpgpost-29-1226822798_thumb.jpg[attachmen
Here mine, brand new got it Friday..... I've been driving around everywhere with the 'line on it this weeknd just to see how it tows and find a balnce sweet spot ;)
Would have considered getting one via Bobby but this one was a lot closer to me.
Now the customising starts.... I think i'll kick off with 12V, running water, mount the compressor, tyre rack, tool box, and hopefully some through-floor ratched tie downs :D
Edited by Marlin
Marlin that actually looks like a trailer from 'Unique Trailers' (re: bobby) as its exactly the same design even down to where the plate is fitted also the sealed off inner guards which I havent seen on any other trailer except 'Unique Trailers'. They have recently opened a shop in QLD too and send them up from Sydney.
I spent about 4hrs trailer shopping on Saturday.
That exact design in 12x6 tandem with used rubber from 'Unique Trailers' is $2950 on road with flat or beaver tail. The build quality is very good and Peter was great to deal with.
'Austrailers' want $2800 on road for the same design in 12x6 but flat tail with side rails. They had 1 in the yard which looked like it had been there atleast a month as the brakes were rusted over and a couple of other little joins had started to rust (possibly just due to lack of paint prep in these areas rather than poor workmanship). I could have taken that 1 for $2600 cash on road but kept looking. The guy there was extremely helpful and they obviously know what they are doing due to the amount of stock they were pumping out.
'Elf Trailers' wanted $2250 for 12x6 + blueslip + rego + GST but to me it would be too much mucking around getting it blue slipped and rego'd when the other 2 shops offer the same design for basically the same price on road.
The interesting think I found was that due to the jigs they have setup for the standard car trailer sizes (12, 14, 15 x 6) that to get a custom made 10x6 single axel would cost me the same because it takes longer for them to measure and cut etc so i'll just get a 12x6 tandem and be done with it.
The biggest problem now is that I keep being told by neighbours and friends whom have owned many trailers to make sure it is galvanized if im not prepared to strip/paint it yearly if it sits out in the weather (which is something I definitely don't want to do). My trailer will only be used about 15x a year so their is no reason why it shouldn't ever look anything but brand new.
I'll have to ring Unique + Austrailers on Monday to find out pricing on galvanized to see what the price difference is. If it's only a couple of hundred i'll get it done but any more and i'll just get regular paint I guess.
Hi,
Here is my trailer that i purchased a little while ago, it is 15ft with electric brakes, ford hubs and 100mm drop axles.
Endend up being $4000 from B&M Trailers, they are selling the standard ones for $3100 which is 14ft a lot higher and cable brakes.
Mattpost-8233-1226827197_thumb.jpgpost-8233-1226827610_thumb.jpgpost-8233-1226827737.jpg
Replied to your PM Ben.
I got a 15ft version, I like to have some room and it might even be better come resale time.... the beaver tail is good, very easy to load and no fluffing about. :P
Edit: Oh, and the floor to guard clearence it 180mm, so my 32 has about 70mm clearance.
Edited by Marlin
Yeah it's charged by the kg so a trailer is pretty dear. The one I've got uses Blue Scope thick wall tube (not China crap) and is Hammertone finished, so honestly, it'll out-last me. Especially if I don't quite smoking soon.
edit: Changed "fagging" to smoking.... woulda left myself wide open.
Edited by Marlin
mmmmmmm fags......
ben, if you want the thing to last just keep it dry. as long as you can keep the thing out of the rain it will look sweet for ages. otherwise they look crap pretty quick. 1 or 2 outings in the wet and they get spots all over.
meh gal for sure if you can afford it. we paint ours every year or 2 (I don't know many people who have enough inside storage for cars, let alone trailers.
just imagine how much fun it is one weekend a year to be wire brushing, priming and painting a trailer when you could be building (yet another) motor for the race car instead
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
