they're the same "98 octane" so is it ok to mix petrols?
or just stick to the onoe bp ultimate? :devil:
there is really no difference between BP98, mobil 98, caltex 98, shell 98. the only differences you get is between servos and batches. sometimes any company will have a bad batch, or some contamination, or you are unlucky enough to buy from a servo with low stock (ie getting fuel from the bottom of the tank) or with old stock. but apart from that it doesn't matter one bit really which 98 brand fuel you buy.
spent a week cruising the hinterland behind coffs harbour last year while the old girl did some business there. I had the luxury of a BP, Shell, and a caltex within 5 minutes of where i was staying so i tried them all. The caltex returned the lowest knock reading of them all. Only talking a couple of points and, as has already been pointed out it could just be different batches causing the slight variance But i wouldnt worry about using any of those 3 in a car tuned to 98 fuel.
Edited by FineLine
well unless i got a bad batch i will have to disagree with everyone
My car was tuned with bp ultimate 98, i never got above 12 no matter what i did
I put in some Caltex vortex 98 and my knock values went through the roof at high rpm. I went to 6900rpm and knock when from 6 to 66 in an instant.
Tune was spot on too
i dunno what it is guys...but in my stock r32 gtst before the half line i can get 230kms with bp ultimate...as soon as i change to something like v power i can get about just over 200-210kms at half way?
but yeh don't think there are probs with mixing petrols...the focus, corolla, swift daily drivers in most cases would probably switch from 4 different brand fuels because they would most likely get whatever is close to them at the time of needing fuel.
I use BP98, Mobil 98 and united 98. Find no difference between either of them. Unless your sitting on the freeway doing the exact speed and accelerating up to speed the same you cannot tell the difference. You might floor it harder for longer 3 times more in 1 whole tank of driving.....you might drive for an hour longer in slightly warmer weather which should make it run slightly richer (depending on ecu).
In terms of knock the turn over the servo has plays a big part in the age of the fuel. Try to fill up at servos that a fairly busy.
  • 2 years later...
@llusions lol I've done the same thing. I realised after putting about 20L in, so just stopped and picked up the 98 and waited for the staff to unlock. You'll be fine running even 91 as long as it is in low ratio, ie 10L out of 60L tank, with the rest being 98 but not recommended. A friend in the country says he carries around a bottle of octane booster, for if he's ever stuck with only 91/95 at a station. Obviously you don't want to do it for long, but as long as the knock is minimal you'll be fine.
Brand wise, they all use the same refineries so really doesn't matter.
98 RON fuel is 98 RON fuel regardless, it is refined to the same standards, so there should be no difference in mixing between brands.
It is generally only bad batches that cause inconsistencies in quality, or if your unfortunate enough to go to a station that has its tanks quite low then you may find minor issues in fuel consumption and power to an extent, but usually not to the extent that it can be noticed from a drivers point of view - maybe only a hand controller or similar showing slightly higher/lower knock readings.
Massive (unsafe) differences in knock levels can only be down to using a lower rated fuel ie: 95/93/91, or an EXTREMELY bad batch of 98, which would be rare.
Further to knock levels and such, as a car gets older especially if it gets out of tune, you might need to increase the octane of the fuel. For example 93 to 95, or 95 to 98. Not so applicable to Skylines, but other 'sports' cars have this problem. Anyway, a good $200 tune should fix that, but just bear in mind you can't always use the fuel in the manual/theory, as reality is different.
personally I have had my car tuned on vpower with a result of 267rwkw and then 278rwkw on the same dyno (different day, however the higher power figure was on a MUCH hotter day)
I only run my cars on ultimate or (manildra e85), and was driving my mates 34 the other day and needed to fill up, the only BP around was closed so I was forced to go to shell. as soon as I left the station the engine check light was flashing under high load.
I have also heard that vpower is a 95 octane fuel with an octane booster to acheive 98ron whereas ultimate is refined as a 98ron
also i know of a few tuners that net lower power figures on shell "fuel" when compared to ultimate.
i dont't have any concrete evidence to back up ANY of these claims, but take it how you want ;)
i do NOT use shell
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
