I dont like how they call him the stig because he isn't the original. just like when they go to africa he was called the stig's African cousin so i think our stig should be called the stig's australian cousin or something like that.
  • Replies 58
Posted Images
Damn, I forget which car they were doing the lap on, maybe the bmw 135?
On one angle the car was looking at sun, and you could see the drivers eyes and some of his face from the sun....
Bakes - did you record that one? go have a look! :P
Top gear Aus is so shit that I doubt it will run long enough for anyone to truly find out. "Australian outback adventure" in 3 European 150,000$ + SUV's, what a joke ..... if I wanted to watch a bunch of tossers in European cars i'd watch the original top gear.
Its Luffy (Ian), the way he sits in the car and holds the wheel is a dead give away :)
None of the V8 blokes can do it due to contract agreements, if you dont believe that just ask them!!!
Who cares? No-one watches TGA anyway :P
+1 eh!
he can't drive for sheeps poo anyway. TGA is a waste of my TV time - BRING BACK TG UK!!! the aussie gys are posers, get rid of them and the show would improve 100%... I mean honestly, using GROUSE is 1 time to many, let alone 3 times in the show!
agreed. I'm the ocker stig and even I don't watch those flamin mongrels on me idiot box. i prefer re-runs of baywatch...
yeeeeehooooo!
Col. Hogan!
If you REALLY must know who the Stig is, you collect all of the Mobile Nos. of...
THE USUAL SUSPECTS and...
you call every one of them during A "SHOOT" !!
I KNOW N-N-N-N-OTHING
Sgt Schultz.
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
